08-31-2020, 07:16 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jul 2020
How much would this cost?
Getting some work done on my car. I have supplied a body shop with the following for them to paint and install. What would be a fair price to have this done?
IVS Havoc rear diffuser: Paint outside larger piece (that goes around exhaust tips) in satin black. Paint inside smaller piece gloss black to match car. OEM ZL1 front bumper conversion kit (everything included): paint gloss black to match car. Paint plastic pieces with satin black to prevent fade. OEM ZL1 Side rocker: Paint top gloss black to match car and the lower plastic section satin black Anvil Auto rear notch spoiler: paint gloss black to match car. owner said block sanding and prepping prior to paint may be needed. Thanks! |
08-31-2020, 07:27 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
600.00 + -
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
08-31-2020, 07:31 PM | #3 |
USA-1
What is the shop quoting?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
08-31-2020, 07:52 PM | #4 |
Shop quoted me $725 cash out the door for just painting the bumper and installing which I thought was fair as I’ve heard just paint for the bumper is $400 or maybe even a little more. So $325 to install was well worth it to me. But then I decided to just go all out and I ordered the side rockers, spoiler, and rear diffuser. I am meeting with the shop tomorrow to go over everything with them (they have all the parts) and to make sure we are on the same page about what I want painted what colors (between satin black and gloss black).
08-31-2020, 08:14 PM | #5 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
Here in NY that's easily $1500-2000 all day.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
08-31-2020, 08:22 PM | #6 |
I would say that's fair, maybe as high as $700. This is assuming minimal prep or repair work needs to be done. Body/Paint shop prices can vary dramatically based on region.
Adding installation to all of this changes things a bit of course. But that should alleviate any fitment issues you may run into afterwards.
09-01-2020, 09:04 AM | #7 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
09-01-2020, 11:52 AM | #8 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Going to vary from location and shop. Could be a small variation or a huge one. To have the parts painted here would be around 800-1000 with minimal prep. That does not include installation
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
09-01-2020, 03:41 PM | #9 |
Going from all the pieces I had painted on my Camaro by my shop and their labor prices plus, having my friend and his shop do the install, because I trusted him more for that part of it, my paint shop though does great work, I would say about the same as mentioned above. ^^^^^
09-01-2020, 04:57 PM | #10 |
Just went to the shop, went through everything with them and got the quote. When they put it into their system it popped up as $2,700 with all the prep, paint, and installation. We agreed to $2,250 cash for everything. Id say this is more than fair as they are going to be painting every single piece of plastic on the front bumper (light bezels, upper grill, lower grill, lower spoiler) as well as the bottom part of the side rocker in satin black.
09-01-2020, 05:02 PM | #11 |
That's a good deal for all that painting. You did good.
09-01-2020, 07:12 PM | #12 |
09-01-2020, 08:32 PM | #13 | ||
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i don't want to be a party pooper but you have to remove the back bumper to replace the back up bulbs i would not pay 325 for that to be done. just me but i would save on labor and do the removal and install of bumpers myself and i would also do my own side skirts.i get it some people don't have a place or the tools but if yo do than do it yourself.the rear is simple.
09-01-2020, 10:03 PM | #14 | |||
Thread Tools | |
