01-09-2018, 10:19 AM | #1 |
Drives: 1968 SS/RS, 2006 H2 2016 2SS White Join Date: Sep 2015
From Drive to M2 without touching shifter?
Driving down the road at 40 to 45 mph. Started to pass a car and stepped on the gas and the car shifted to m2? I immediately let off gas and shifted up in to neutral. Then back down to drive and it remained in drive??? Happen to anyone else?
2016 2SS White fully loaded
01-09-2018, 11:21 AM | #2 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
You may have accidentally flicked the paddle behind the steering wheel? Even in D, if you hit the paddles, the car will temporarily go into manual mode.
01-09-2018, 02:10 PM | #3 |
Drives: 2016 Mosaic Black 2SS, NPP, A8. Join Date: Jun 2016
You kicked in performance shift mode. Hit the gas quickly and it kicks in very easily if you are around 40mph or more. You can kick the shifter to the left and the back to the right to kick it back out of that mode. I would not shift the car into neutral and back into drive unless absolutely necessary.
Sent from the mobile client - Forum Talker |
01-09-2018, 08:30 PM | #4 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
If it shifted to M2 then it wasnt performace shift mode - he must have hit the paddle on accident.
01-10-2018, 06:45 AM | #5 |
I've done this at the drag strip accidently by having my hands in the wrong position after I launched the car and I knew it when I did it and was able to react quick enough so I didn't have to abort the pass. It popped right up on the dash and I knew I'd barely toughed the paddle shifter.
01-10-2018, 10:31 AM | #6 |
I guess it was driver error, thank you
