05-20-2020, 06:18 PM | #1 |
Drives: 2018 1SS 1LE Join Date: Jul 2012
Rough cold start/idol
Finally got to drive my car a little with the PC. Anyone know why the first 60-90seconds is rough and “herky jerky”? After a min or two...it runs great and I can’t duplicate the issue. Only happens on cold starts. Plugs? I’m running PCs Canned tune....for a few more weeks at least.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD |
05-20-2020, 08:47 PM | #2 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Could be misfiring. I had the same issue where it was rough on cold starts only and then after it calmed down it was fine. I would sometimes get a flashing check engine light indicating misfires. I used hptuners to see what cylinders were misfiring and I had to replace 2 injectors to fix it. I'm not supercharged though so it might not be the same issue.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
05-20-2020, 08:53 PM | #3 | |
05-20-2020, 10:01 PM | #4 |
I run 2 steps colder NGK, no issues.
2016 NFG 1SS A8
05-20-2020, 10:17 PM | #5 |
Does the fact you are significantly more power than me play a factor? Or that I’m running a canned tune? It’s really weird....it only last about one minute and then it runs great.
05-21-2020, 07:00 AM | #6 |
What plug gap are you running? Very tight plug gaps tend to make cold starts & idling funky.
05-21-2020, 08:10 AM | #7 |
I did what the manual said....035.
05-21-2020, 08:25 AM | #8 | |
I retune hundreds of procharger cars and everyone is much happier after I get done. Give me a call I will get you headed in the right direction.203-753-7223 Ted.
www.jannettyracing.com
05-21-2020, 11:13 AM | #9 |
power is irrelevant...my guess is it's the canned tune.
2016 NFG 1SS A8
