05-02-2020, 08:40 PM | #1 |
Drives: Camaro ZL1 Join Date: Jan 2018
Gas can recommendation to take some E85 to the track?
I am planning to run approx. 30 % Ethanol the next track day making use of that flex fuel mapping. Unfortunately, there is no E85 gas station nearby and I have to bring some in my car. Does anyone have agood reconmendation for a nice gas can? Preferably around 5 gallons and should fit the boot of the ZL1. cheers cirpower
05-02-2020, 09:00 PM | #2 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
I've had good luck with these, they sit pretty sturdy/solid.
https://vpracingfuels.com/product/vp-surecan/?c=237 https://www.surecanusa.com/gascan I also use either the smaller blue or larger grey FloTool Multi-Purpose Funnel, which helps too... https://www.google.com/search?client...UTF-8&oe=UTF-8
05-04-2020, 11:04 AM | #3 |
yup vp is what i have but i only have to bring 91 not e85
05-04-2020, 12:22 PM | #4 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
+1 for the VP cans. Really just make sure it's something without one of those things you have to hold to pour it out. I made that mistake of just getting one from Home Depot, and got annoyed with it and never used it.
05-04-2020, 05:51 PM | #5 |
Thanks for the answers! Really appreciate it.
Do the VP cans fit in the trunk though? They do look pretty tall? |
05-04-2020, 05:53 PM | #6 |
the one i have does not fit upright lol kinda sketchy the first time i filled it up as it spilled out as i didnt have the top tight but they do fit fine on sides
05-04-2020, 06:11 PM | #7 |
The "Surecan" does, two fit nicely in the Vert trunk (10 gal). The "Motorsport Container" square or round typically has the hose in the cap. (I have one of those left, that I do not use for the car/track purposes) So you would need additional caps w/o the hose for each container for transport, I would think. That's if it were even to fit. I have my trunk lining gutted out at this point so I can not test my "Motorsport Container" for height w/o the hose. Hope that helps? lol
05-09-2020, 04:26 PM | #8 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
These cans fit perfectly 3 side by side at the very back of an SS 1le trunk with zero wiggle room. They are 5.3 gallon cans. If i need to bring only one i place a full one in the middle and 2 empty ones on each side to lock it in.
Anyway, it has worked for me for 3 yrs. Cheers! |
05-17-2020, 07:53 PM | #9 |
Thanks for all the feedback. I did go with 13 dollar cans eventually, as I decided to trailer my car to the track and am not that worried about the back of my truck.
