04-28-2020, 07:00 AM | #15 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I'm curious, what dampers are you thinking of getting for that cheap? I would be very surprised if there was one that costs so little the would give you the MRC Track mode equivalent feel you wanted while keeping your OE springs.
2017 SS 1LE.
05-05-2020, 09:14 AM | #16 | |
Drives: 2016 2SS Join Date: Oct 2016
I ordered from RockAuto finally, they were the least expensive even for Canada. If you choose Fedex as the carrier, they include all taxes and duties. Hope I ordered the good thing hahaha. Is it easy to install? I mean my local shop should be able to do the replacement easily? Anything special to know? Thank you every one, I think it is better to just keep using electronic damper. ACDELCO 84219920 Shock Absorber (8708.80.3000)CAD$ 349.92CAD$ ACDELCO 84219921 Shock Absorber (8708.80.3000)CAD$ 345.70CAD$ |
05-05-2020, 09:56 AM | #17 | |
I was looking at OEM Camaro SS damper on Camaro w/o magnetic ride. In any case, I just ordered electronic damper, see my post above. I think it is better that way. |
05-06-2020, 09:13 AM | #18 | |
As for the install it's pretty straightforward and any competent shop should be able to do it. Only extra step is to plug in the damper lol. Also have to make sure the ride height sensor doesn't get over-extended or otherwise broken during the process, but other than those two things it's exactly like installing it in any other car.
2017 SS 1LE.
Tags |
magnetic, mrc, shocks, strut |
Thread Tools | |
