Old 05-02-2021, 10:41 PM   #1
GAOLDGUY
GAOLDGUY's Avatar
Drives: 2012 GMC Sierra, 2018 Camaro SS 1LE
How Sensitive Is The E-Diff?
I've read a good bit about how sensitive the electronic differential is on the SS 1LE. I would NEVER try to use a different profile in the event of a flat but I can't imagine the pump and fix-a-flat in the trunk work well. So, if I had a flat could I replace one side on the back with the exact same type tire, in the factory size but new? For example, my summer tires are the factory size 305/30/20 PS4S. Would I need to buy 2 if I needed to replace only one so that they would be the exact same size and not freak out the computer? OR, would a few millimeters be OK? Just curious.
GAOLDGUY is offline   Reply With Quote
Old 05-03-2021, 07:34 AM   #2
street sweeper
Drives: 21 1SS 1LE, 14 Escalade
curious myself, considering i just had to replace one of my rear tires that picked up a screw. Car only had 1800 miles on it, 90% highway/light driving. I figured i was fine due to the mileage and nature of use the tires had experienced. I didnt actually measure the tread depth, but to the naked eye the new and old tire were basically indiscernible. I also monitored the e diff display for the first couple drives to see if it was activating at a higher rate than what i remembered to be normal, i did not notice anything out of the ordinary there...
street sweeper is offline   Reply With Quote
Old 05-03-2021, 08:56 AM   #3
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
The eDiff won't care about the difference in wear or tread. But it WILL care if you mix/match sizes.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 05-10-2021, 04:32 PM   #4
FH212
FH212's Avatar
Drives: 2021 Camaro SS 1LE
Well the stock Goodyear's have so little tread new Vs bald I would seriously doubt it would matter.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 05-10-2021, 07:05 PM   #5
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Most track and high performance summer tires have so little tread depth I'm sure it would never exceed the cooked in tire diameter allowance/programming. I have 4S's and at $550 a rear tire I'd test it out.
Warrior102 is offline   Reply With Quote
Old 05-10-2021, 10:32 PM   #6
GAOLDGUY
GAOLDGUY's Avatar
Warrior102 - Exactly! I agree. Through an odd sequence of events, I ended up with a duplicate set of 1LE wheels for the summer and they had 4s' on them as well. I thought that if I had a flat, I would prefer to only purchase 1 tire rather than sell a kidney. I've been running the EDIF screen so that I know what "normal" looks like, just in case.
