04-30-2021, 12:38 PM | #15 |
Drives: 2020 2SS 1LE Satin Steel Metallic Join Date: May 2020
How many miles when you guys did your first oil change? Did you do transmission also or prior? I have an M6
04-30-2021, 03:30 PM | #16 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Get the diff fluid done early, I would say 1500 miles. You'll surprised how much black goop is on the mag drain plug.
I also use Amsoil Severe Gear with slip lock. Best synthetic diff fluid available based on my research and experience (although I prefer bottle/pump). GM doesn't produce oil, they market a product https://www.amsoil.com/p/severe-gear-75w-90-svg/ |
04-30-2021, 03:59 PM | #17 |
Same with the transmission? 1500 miles?
04-30-2021, 04:03 PM | #18 | |
04-30-2021, 04:16 PM | #19 |
Drives: 2017 ZL1 Join Date: Apr 2020
Agreed
2017 ZL1 M6 Silver Ice Metallic
04-30-2021, 05:19 PM | #20 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
04-30-2021, 07:18 PM | #21 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
I used the Royal Purple gear oil, prolly gained a horsepower and a torque or two.
05-01-2021, 10:31 AM | #22 |
Drives: 2020 ZL1 Camaro Join Date: Apr 2021
When changing the rear end oil, is there a limited slip type of additive that is needed, or is it just straight oil?
05-01-2021, 10:49 AM | #23 | |
I cannot speak on the other oil others are mentioning but the GM recommend oil works very well. |
05-01-2021, 11:51 AM | #24 |
05-01-2021, 11:52 AM | #25 |
05-02-2021, 12:05 AM | #26 |
Royal Purple usually fares the worst in standardized tests. Their gear oil is junk, and so is their motor oil (the filters are good). It's not about what your buddy uses or what GM is marketing, recommendations must be based on science
Yes, this is an Amsoil site, but I've seen these tests performed independently on numerous forums and Amsoil gear oil consistently comes out on top http://www.syntheticoilhq.com/gearoi...risontest.html |
05-02-2021, 04:51 AM | #27 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
I always read that Royal Purple is good quality oil.
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
05-02-2021, 07:34 AM | #28 |
Kevin
Drives: 2018 Callaway Camaro ZL1 1LE Join Date: Apr 2018
Use Royal Purple gear oil. Over 9000 track miles with it and through several gear oil changes. No metal sludge on the drain plugs anymore.
