04-23-2021, 10:00 AM | #1 |
Drives: 2021 Chevrolet Camaro LT1 Join Date: Apr 2021
2021 LT1 non-bose and no factory amp
I need some help. It seems there are so many varieties of stereo combos in these cars. I have the 7" screen, no amp and cannot figure out where to tap into the speaker wires for high level input to an amp.
I really don't want to cut new factory wires and the only plug and play harnesses require the vehicle to at least have a factory amp. Last edited by MP40cal; 04-23-2021 at 10:50 AM. |
04-23-2021, 12:04 PM | #2 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
You need a breakout harness that plugs into the Radio Module behind the dash to the right of the glovebox. I used the one I linked (I actually asked them to make it in the first place!) and it's perfect - not even hard to install. It will break out the front channel speaker signals (+/-, L and R), which are the correct full-range signals to use. The rear signals are not full range. I made a thread that sort of shows the installation of this harness.
Matt Miller
2020 SS 1LE |
04-23-2021, 01:28 PM | #3 | |
Drives: 2021 1SS, 1969 Convertible Join Date: Aug 2018
2021 1SS Coupe 6MT
1969 Convertible Muncie 4-Speed |
04-23-2021, 02:32 PM | #4 |
Oh! That's a good catch. Yeah, I don't have the full service manual for a 20 or 21 Camaro to check if they are really different or not. I would suggest that the OP call Gen5DIY and ask them what the differences are. Really, if the new LT1s are coming without an amp in the trunk at all and a different set of connectors for the smaller display, then Gen5DIY might be interested in making the correct breakout harness for them. I would think there will be far more LT1s sold than SS 1LEs in any given year, so their customer base would be significantly greater for the LT1 crowd.
Matt Miller
2020 SS 1LE |
