03-18-2021, 10:03 AM | #1 |
Drives: 2017 Camaro 1SS Nighfall Gray M6 Join Date: Feb 2017
Oil temp question for the camaro hive mind
So, I have noticed something rather odd. Driving my 2017 1SS, my oil normally sits at about 185 to 190 or so during cruising in the summertime. However, during winter, it cranks up to 225 to 230! Is the car able to somehow divert from the coolers during winter to keep the temps from dipping down too far? I have no idea why this happens, 230 is well within operating temps for the oil, and 185 may be a hair low as it isn't above the vapor point of water. Just wondering if anyone else has noticed this happening.
2017 1SS M6 nightfall gray metallic, Lingenfelter 378 CID N/A package, MSD atomic airforce intake manifold, 97mm. Throttle body, 2" kooks longtubes, 3" borla S-type catback, big fat tires and everything.
03-18-2021, 12:22 PM | #2 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
I've only driven during winter really, but I noted the temperature on longer drives tends to stay over 200, dunno if it was 220-230.
I guess I will see, summer starts in about a week or 2 here.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
03-18-2021, 03:15 PM | #3 |
I get the feeling it has to do with ambient temperature at startup, could be wrong though. Wish I could pick an engineers brain who worked on the engine.
03-22-2021, 02:48 PM | #4 |
I have 2018 SS. Also driven only in winter (picked it up in December).
I will keep an I on this |
03-22-2021, 04:51 PM | #5 | |
A couple of thoughts come to mind and here are a few questions. First question (gotta ask) is are you low on oil? Are you using factory gauges to get your data? Maybe during the summer the fans are turning on to keep the car cooler because of running AC (if you use it in the warmer weather).
03-23-2021, 05:08 PM | #6 | |
03-23-2021, 05:51 PM | #7 | |
03-24-2021, 11:15 AM | #8 |
Well, I think the issue is a cooling issue now, not an oil issue as I first suspected. Maybe putting it in storage over the winter, something in the coolant drifted down and closed off a hose somewhere, or restricted flow. Picking it up in a little bit, we shall see how the coolant and oil behave.
03-25-2021, 02:18 AM | #9 |
Well, coolant flush didn't help. Back to square one. Lingenfelter installed a 160 degree Tstat during their upgrades, but the dealership didn't even make a note of it, they just said the Tstat is "working" so frankly I don't think they actually checked it. Ordered another one from Lingenfelter, probably do the install myself as it is a simple three bolt job on the front of the engine block and easy to get to. Will update once that is complete. If that doesn't fix it, I'll be completely bamboozled and will probably have to really let a pro puzzle through it.
03-25-2021, 07:12 AM | #10 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Most likely you are correct in it being a thermostat issue. The oil cooler is a liquid to liquid plate cooler, meaning the coolant cools/warms the oil. Under street driving conditions they should almost always be close the same temperature, which is what you have noticed because both temps are up.
Old Ride: 2016 Callaway SC630 Camaro SS
03-25-2021, 10:27 PM | #11 |
Drives: 2018 NFG ZL1-1LE Join Date: Jun 2018
This is an interesting read. Here is my 2 cent theory. Again, just theory. The oil cooler is cooled by the engine coolant flowing through it. During colder weather, the thermostat closes off to reduce the flow of coolant to regulate engine temps. This reduced flow of coolant extracts less heat from the oil cooler resulting in a slightly higher oil temp. I could totally be wrong but this seams to make sense in my head. Maybe someone with a higher work knowledge of the system can confirm or point out the error of my thinking.
03-26-2021, 08:02 AM | #12 | |
03-26-2021, 08:50 PM | #13 |
03-29-2021, 09:50 AM | #14 |
Correct, but it does not change it's set point based on the outside air temperature.
