02-03-2023, 11:41 AM | #1 |
Drives: 2018 Camaro 2SS Join Date: Jan 2023
6th gen repairs
Has anyone had to replace the fuel tank pressure sensor on the 6th gen SS and has anyone had to deal with the "service power steering" alert that pops up on the dash?
02-03-2023, 12:30 PM | #2 |
Fuel tank pressure sensor is easier to get to than I had suspected. At least you don't have to drop the tank.
from the repair manual: "In right rear wheel well, rear of wheel, on evaporative emission pipe" |
02-03-2023, 07:19 PM | #3 |
Dealership says it's not covered under my extended warranty and wants $800. I only have 30k miles on the car. Seems like GM should step up and cover it.
02-03-2023, 07:44 PM | #4 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
You should carefully read every page of your original warranty and your extended warranty. Many times the dealership service people don’t know what’s covered. If that sensor would happen to be part of the emission system, I bet the original warranty might cover it. The GM extended warranty’s often say if an item isn’t mentioned as not covered, then it’s covered. For $800, it’s worth checking.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
02-04-2023, 08:30 AM | #5 |
Yes, read your extended warranty. I would think that would cover a sensor. The federal emissions 8 year warranty only covers major components, so that will not apply.
$800 sounds steep for this. Probably a $20 part you can replace by pulling back the wheel liner. |
02-04-2023, 07:49 PM | #6 | |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
Its not a normal wear item. I would fight them. I also have an extended warranty from the dealer. I have over 60k miles on my 17' . Who is backing your warranty? Its usually a secondary company that works with the dealer. |
02-04-2023, 08:21 PM | #7 |
It's definitely a secondary company out of Memphis. I have never had this happen, but they had to send out an inspector to ok the repair on the steering gear which equals me being without my car for almost 2 weeks now and I haven't even made the first payment.
02-05-2023, 09:33 PM | #8 | |
You bought it used? |
02-07-2023, 12:52 AM | #9 |
Yes.
