01-03-2023, 09:03 PM | #1 |
Drives: 2017 Camaro 1SS Join Date: Mar 2019
Weight reduction
What are some parts that you have taken off your car for weight savings?
I know the back seats weigh around 30 pounds and it’s fairly easy to remove! |
01-03-2023, 09:16 PM | #2 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Seats, wheels, rotors are probably the easiest I would think. Then you can go and start stripping the rest of the inside and airbags. Replace glass with window netting, get lighter doors. Ect
I got lighter wheels for this next season 18", I'll see how much of a difference it makes. |
01-03-2023, 09:26 PM | #3 |
Drives: 2014 Z/28 Join Date: Jul 2022
Antigravity battery would save about 20lbs, and bucket seats save up to 40lbs depending on mounts.
01-03-2023, 10:57 PM | #4 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
I have saved a couple pounds not sure exactly have have the weight on some of my threads. I have the following that has saved me some weight Racetech seats, SPL suspension parts, BMR motor mounts, Apex wheels .
01-03-2023, 11:59 PM | #5 |
Body fat, if applicable
01-04-2023, 11:06 AM | #6 |
keto diet lost 60lbs
rear seat delete antigravity battery full spl parts kits and full coilover kit sparco driver seat and 5 point harness
01-04-2023, 11:22 AM | #7 |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
I picked up some carbon fenders that are 3-4lbs each. But I was surprised when I weighed the stock fenders to find those were only 10lbs each.
01-04-2023, 03:20 PM | #8 |
hahaha I'm on the Keto diet now so I hope that helps also!
I need to look into the antigravity battery .. ive heard great things about them! thanks for the input guys |
01-04-2023, 04:01 PM | #9 |
i did keto lost 60lbs in 6 months but now im on carnivore i love it ! got a traeger and smoking up different meats every weekend keeps me busy in the off season of racing
01-04-2023, 07:35 PM | #10 |
Wow dude! That’s a lot of weight reduction! Keto might be one of the only diets that work for me, and somehow always keep me full. I love it!
01-04-2023, 09:28 PM | #11 |
Drives: 98 Camaro Join Date: Apr 2022
What SPL parts are you guys replacing and getting good results and weight savings?
01-04-2023, 09:57 PM | #12 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
When my factory tires wore out I got non run flats and lost 4-5 lbs per tire. Tire rack has forge one 19-9 wheels that fit. They are 20 lbs , 10 lbs lighter than factory wheels. They cost $634 each. Think it will drive much better? Street driven only.
01-05-2023, 12:32 AM | #13 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
Are you drag racing or doing autocross/roadcourse ?
I dropped 200lbs from 15” conversion all the way around and aerospace front and back but that’s for drag racing . Last edited by Duramacr1; 01-05-2023 at 12:34 AM. Reason: Added more |
01-05-2023, 07:13 AM | #14 |
Im doing autox. I have lighter wheels and non run flat tires, but I do have wider tires than stock so I think it evened itself out weightwise unfortunately.
