Old 11-03-2022, 03:24 AM   #1
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Bolt on set up time slips and comparisons
What’s up guys thought I’d share some time slips and what set up it took to get there. I’ll try my best to be accurate with DA and Race Weight.
Anybody who would like to share their results are welcome to share.
Murder6.2 is offline   Reply With Quote
Old 11-03-2022, 03:51 AM   #2
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Here is the cars baseline. I believe this was my best time bone stock. On the stock tires. On 91 octane fuel. 100% full weight 1/2 tank of gas.
DA was 1800ish. WR had to be 3900ish. Car is a 1ss with a sun roof. I’m about 220lbs
Old 11-03-2022, 03:54 AM   #3
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Rotofab Dry/Catdeletes/tuned on Flex fuel by Newera Performance in Socal.
305/45/17 Et Street R on a Racestar wheel . Also went from the stock front tire to a 285/35/20 Nitto G2 on a 1LE rep. And now the car has aftermarket Braum seats shaving off 40lbs.
1500 DA 3850WR (Approximately)
Old 11-03-2022, 04:03 AM   #4
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Made the Switch and got Tuned by Brett from Pray Performance.
That was the only change from the above. Still just ECM tuned only
Rotofab/Cat delete/Flex fuel tune. Same wheels and tires and same weight.
2000DA 3850WR (Approximately)
Old 11-03-2022, 04:08 AM   #5
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Same Bolt ons but now I switched from the heavy 285/35/20 Nittos G2s on the 1le wheels (59lbs) and went with a 18x8 F14 with a 235/50/18 street tire (43lbs)
And I got my TCM unlocked and tuned by Brett
2500 DA 3800 WR
Old 11-03-2022, 04:16 AM   #6
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Fast Foward about 6 months, I decide to change the intake set up.
Stock Air box, Non ported LT2 manifold from GPI, CA catdeletes pipes, same Flex fuel tune by Pray Performance (No retune) Same wheel and tire set up.
1400DA 3800lbs WR (Approximately)
After this it becomes a money pit and I rather not relive that LOL
You can check out my road to 6s thread for all that.
Old 11-05-2022, 07:02 AM   #7
cjperformance
cjperformance's Avatar
Are the front 18" F14s off the shelf or did you have to custom order them? Looking for some fronts to match my rear F14 drag.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 11-05-2022, 08:54 AM   #8
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Not sure why you took off the Rotofab and went back to the stock air box.
Old 11-06-2022, 03:23 AM   #9
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Off the shelf from Dragracingwheels.com
Old 11-06-2022, 03:26 AM   #10
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Comiefornia “under your hood enforcement” wrote me a nice $500 fine for it
Decided to go with the stealth look
Ahole would’ve never known if it didn’t say “ROTOFAB” on it
Old 11-06-2022, 06:59 AM   #11
laynlo15
laynlo15's Avatar
Really? Did you get stopped for something and they checked?
Old 11-07-2022, 04:22 AM   #12
Murder6.2
LIL SLOW SS
Murder6.2's Avatar
Drives: 2017 SS
Yeah, window tint stop turned into a $500 fine for a Air filter lol
