11-03-2014, 07:58 AM | #57 | |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
I responded respectfully and with a valid counter argument to the original agitator in post 34. But that post remains and mine is gone? The 1LE has parts from the ZL1 and is the budget track brawler. It is an accomplished budget racer. The ZL1 is a grand touring power house. Is faster than the 1LE in all areas but can heat soak and is heavy. On the strip it is king besides the COPO. The Z/28 is the car for track junkies and gives both the 1LE and the ZL1 a whopping on a track day. But it comes at a premium that some can't afford including maintenance costs. In the end it comes to cost. The guy who would not own an FI car because of heat soak is a track minded person and the Z/28 is the car for him. Unless money is an issue then the 1LE makes perfect sense. Last edited by 2013 ZL1 #7860; 11-03-2014 at 08:19 AM. |
11-03-2014, 11:08 AM | #58 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
For me, and I'm a picky and specific SOB, ZL1 over a 1LE every time. Even if both were the same price.
11-03-2014, 12:04 PM | #59 | |||
Track > 1/4 Mile
Here's a quick video from the track day this past weekend. Mid way through the video I get stuck behind a 2013 GT500... so slow..
11-03-2014, 03:31 PM | #60 | |
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV Join Date: Feb 2013
The 1LE shouldn't be down only 2 seconds at Milford with a 154hp disadvantage, but it is. This shows the 1LE chassis setup is better in the handling department. Give a 1LE 500hp at the crank (bolt-ons) and it's right there with a ZL1 on a road course. Let's see what time that ZL1 is running on the 3rd, 4th, 5th lap.
11-03-2014, 03:38 PM | #61 |
Drives: 2013 ZL1 Join Date: Oct 2013
Must be all the long straights at milford where the horsepower really shows up via time..
2013 Silver ZL1
11-03-2014, 04:03 PM | #62 | ||
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
11-03-2014, 04:05 PM | #63 | |
Drives: 2014 ZL1 Join Date: Apr 2013
EDIT: I see HOTLAPZl1 had the same thoughts as I. I need to type faster...
Grasping at straws at this point. Let's add 75 horsepower to one car, let's make up heat soak on the other car and call it even. Does the ZL1 pull some timing when it is hot? Sure. But let's not pretend it is a one lap only car. In case you missed the GT500 vs Zl1 Laguna laps, here is what Motor Trend found on the Zl1 as an exact quote "The ZL1, meanwhile, never deviated by more than two-tenths of a second." That was in the hands of Randy Pobst, pretty sure he was working the car hard. While you are adding the 75 horsepower to the 1LE, better add some brake upgrades as well. Want to compare multiple laps? You'll need to fix the brake fade that is sometimes reported on these forums. Again, as I've said in this thread, both are great cars, and I think Chevy is doing an excellent job with multiple options for the track and enthusiast, but people are starting to just about make up stuff to justify their preference. |
11-03-2014, 05:13 PM | #64 | |
Did you see how close the 1LE was with the Z28 when MT did the tire swap test? When you add 75 crank hp to a 1LE, keep the weight the same, keep same gears (1st-4th ratios with 3.91 rear), and add better brakes guess what that makes a car similar to the Z28. Which beats the ZL1 by 3 seconds on the short Milford course.
11-03-2014, 05:19 PM | #65 |
Must have missed that.. so us the same driver laps at milford
With the zl1 and z28.. love watching videos..
2013 Silver ZL1
11-03-2014, 05:29 PM | #66 |
People quote the magazine article because it is hard evidence that heat soak does not readily effect lap times on a road course on a stock car. There is no evidence it does. Not sure how else anyone would take that. You can read tons of posts here in this very forum that there is plenty of heat soak issues drag racing. Also beyond drag racing with modified cars (particularly those running more boost than stock). Don't think I've seen a post where anyone with a stock car has had worsening road course lap times in the standard 20-30 minutes sessions. With the car stock and moving, it just isn't a relevant issue (judging from the posts on this forum and the magazine articles, all I have to go on). Judging from the tables, we think the car will pull some timing, at track temps, but doesn't seem to be a relevant amount to impact lap times. I'll be logging the timing in the spring when I'm back at the track, and will report back.
11-03-2014, 05:39 PM | #67 |
Drives: 2023 ZLE Join Date: Jun 2009
This thread is bordering on absurd.
11-03-2014, 05:49 PM | #68 |
Bordering?
2013 Silver ZL1
11-03-2014, 06:20 PM | #69 | |
The 1LE is a fine auto but it is not a Z/28... or a ZL1
11-03-2014, 07:41 PM | #70 | |
Drives: 2019 ZL1 1LE CRUSH Join Date: Jun 2013
2019 ZL1 1LE 6-Speed
----------------------------- Kong Ported Supercharger, Nick Williams 103mm Throttle Body, Roto-fab Big Gulp CAI, Kooks 2" LT Headers, AWE 3" Touring Exhaust, Cordes Expansion Tank, Mighty Mouse Catch Can, MS Tuning -- 661whp & 684ftlbs |
