02-23-2020, 10:54 PM | #15 |
2020 Shadow Gray 2SS
A-friggin-MEN! This has been my motto for 40 years... The ONE time I fogot it I ended up with a motor going though a quart of oil every 600 miles! NO THANK YOU! NEVER, EVER AGAIN!!!
My 2020 2SS is getting an oil AND Diff fluid change at 500 miles, 1,500 mile and 4,500 miles... Does it REALLY need it for a non-tracked car??? Probably not, but it is the most conservative maintenance schedule I could find and the $300 or so investment is WELL worth it to protect my $50k car... ABSOLUTELY!!!
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
02-23-2020, 11:16 PM | #16 |
it says it meets the spec its fine. they had to pay GM alot of money to put that label on there oil.
02-23-2020, 11:19 PM | #17 | ||||
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
If it passed the test, it does have something to do with the quality, because, it, uh, passed the test, right? And that means it can be safely used in that motor with no adverse effects, huh? Quote:
Do I need a better filter media at the expense of oil volume and pressure? Would that require a larger filter to hold more media? What about your fancy super filter plugging up the media quicker and causing the bypass to pop and then I get NO filtration. Or the restrictive media causing a partial bypass. How would that be helpful to engine longevity? Quote:
Dexros2 oil is Dexros2 oil and will not hurt the motor in any way. |
02-23-2020, 11:27 PM | #18 | |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Spend a little time over at BITOG forums. Who knew we were all wasting so much money on uselss oil when "sams club" had my back. |
02-23-2020, 11:27 PM | #19 | |
Dumb Ass Deluxe
I had an 02 C2500HD and it had them too. There are 11 total. You could probably cock the tires and see the upper BJ fitting pretty easy. Sometimes the BJ is tapped and threaded but there is a plug screwed in instead of a zerk. I have only occasionally seen that on brands other than GM though. |
02-23-2020, 11:30 PM | #20 |
Dumb Ass Deluxe
02-23-2020, 11:35 PM | #21 | |
But hey, maybe the Sam's Club oil IS "Dexros2"! Thank you very much, I'll stick with Mobil 1 0W-40 ESP Formula (Dexos2) for my $18.5K engine (factory recommended)
02-23-2020, 11:40 PM | #22 | |||
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
So much wrong with this molecule damage I won't even bother with it. Quote:
Must be horrible stuff that GM backs its warranty to. Quote:
We have a winner. There is a lot wrong with a lot of statements in this thread. Dexos 2 is for all the bullshit catalytic converter requirements we got force fed from the last idiot in office under the 2012 EPA mileage mandates. ANY MOTOR OIL THE MEETS DEXOS 2 SPEC of the proper weight is more than acceptable. Crazy fact, you could run them on non synthetic and your engine would be fine....... Please for the love of God, go read up on what qualifies as a synthetic nowadays as I could pee in a bucket and whirl a ball in the pee for 3 minutes and qualify....... Here is the key parts u need to worry about, proper spec per manufacturer(for your warranty) and changing your oil on schedule or earlier. If you're buying boutique BS oil and changing it every 3k miles you're making yourself poorer. Think of it like this, everyone fawns over the AC Delco filters because they are the "best", same bottom bidding company will be making the next batch which is different from the last batch :-) (I like Baldwins for constitency personally) |
02-23-2020, 11:46 PM | #23 | |
02-24-2020, 12:59 AM | #24 | |
Long hauler
Seems like all SuperTech oils that are Full Synthetic have the certification now |
02-24-2020, 06:23 AM | #25 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
If it meets the Dexos2 requirement, it is fine for your Camaro. Your engine does not know what brand of motor oil goes into it, that is largely a feel good thing for owners. Yes, different oils have different additive packages and there are some which are likely “better.” But for day to day driving with regular oil and filter changes you’d be hard pressed to see the difference after 50 thousand miles. Have an oil analysis done after an oil change and see what shows up if you are concerned.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
02-24-2020, 07:00 AM | #26 | |
Dumb Ass Deluxe
As far as sticking with Mobil1, it *might* be a "better oil" than Sam's Club oil. But, the cheaper oil won't hurt your engine since all the minimum specs are met. (Provided you follow recommended drain intervals). |
02-24-2020, 07:03 AM | #27 |
I don’t understand all of this arguing about brands of oil to use. If it is Dexos2 and synthetic then you can use it in your engine! I get flack from my friends about using Valvoline instead of Mobil 1 in my ZL1 but it’s fine to use because of the rating. Also I’m hearing that I should switch to 0W-40 instead of using 5W-30 what the engine is supposed to use unless I’m tracking the car. There is too much grumbling and arguing about oil brands and grades in my opinion! Run the brand/grade of oil you want to use and roll on!
02-24-2020, 07:04 AM | #28 |
Dumb Ass Deluxe
