#57 | |
![]() ![]() ![]() ![]() Drives: 1970 chevelle Join Date: Aug 2011
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
#58 |
Duplicated issue is a huge plus...
#59 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Ted.
www.jannettyracing.com
#60 |
Nothing we did to the suspension, tires alignment, corner weights, tire pressures, conditions, with and without passenger has any affect on it.
Does it ever time. Ted.
#61 |
Ted's issue is separate from the "Floating" feeling that some/all? ZL1 owners experience. Thankfully GM has gotten the issue, but hopefully it gets resolved in some sort of a timely manner. I'd be pushing for a buy-back myself.
I haven't driven my ZL1 yet but I'm guessing it's guaranteed that I'll feel the rear end float. Possible that both Ted's problem and the "floating" feeling are both related to a new fangled ELSD that maybe wasn't quite ready for production? |
#62 | |
#63 |
I used to be Dragoneye...
Does it continue to "steer" left until you let off the throttle? Or does it jerk the car over at first, and then hold steady?
#64 |
Update, back to the dealer yesterday afternoon, Tech hooked up a the MDI, and Service manager brought out some tech bulletins.
They wanted to verify the Steering sensor calibration as someone mentioned above, and it was fine, they did a calibration anyway. NOTE to guys complaining about the Trammelling as GM calls it, or Wiggle on acceleration, there is a reprogramming update released March of 2018 to address this. They applied this update to my RDCCM, Rear Differential Clutch Control Module. They also found a code for a Clutch control command permanently failed. I may have worded this incorrectly but that is how I remember it. So They are trying to get an OK to order a new Differential. Waiting ![]()
#65 | |
Hopefully yours gets resolved! Sounds like you're on the right path. |
#66 | |
Ted.
#67 | |
#68 | |
I suspect is applies more even torque to the right and left clutches with a wider window of Steering angle. Just my Opinion no facts. Ted.
#69 | |
![]() Drives: 2017 ZL1 A10 Nightfall Gray Join Date: Jul 2017
#70 |
Meant "recalibration", not "recall", my bad.
Thread Tools | |
