05-11-2018, 01:02 PM | #1 | ||
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Nightmare Camaro/Dealership Problem
So I have a 2011 Camaro SS LS3 ~21K miles longtube headers, dyno tune, and other basic mods and it is at the dealership right now for the 6th time for the same problem!!! They can’t seem to figure it out. The only reason I keep going back is because I only had to pay for the 1st visit like $700-$800. These are the parts they replaced and in this order:
1) pos/neg cable that runs from battery to engine 2) starter relay 3) starter 4) ECM 5) fuse box Here is the problem: Scenario 1: When I turn the key it does a loud click or 2 or 3 before it cranks. This doesn’t happen every startup. (nighttime video) Scenario 2: I come out to the car and try to crank it and nothing happens. And a jump start does nothing. I have to push start. It makes a sound coming from the relay I pointed at. This doesn’t happen often but when it does I would be stranded (daytime video) Also one time while I was driving the service stabili trac message and light randomly came on while I was driving. What should I do? What do you guys think is the problem??
Pity a man in familiar places, who yet feels like a stranger.
05-11-2018, 01:19 PM | #2 |
BUMBL Z
Did you have the battery and alternator tested?
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
05-11-2018, 01:32 PM | #3 |
I'm pretty sure they tested everything in their protocol the many times it was there.
05-11-2018, 01:37 PM | #4 |
Drives: 2010 Camaro 1SS Join Date: Nov 2015
Clicking when starting sounds like a bad starter. Since you've already replaced that it might be a good idea to check the cables running from the starter.
EDIT: Sort of related... the other day while working on some electrical equipment I found a cable that looked good from the outside but was bad on the inside. Using a multimeter I was able to see that it was bad. I ended up replacing it but was curious as to why it was bad. After cutting it open I found that the cable had torn on the inside. Is it possible that perhaps yours is torn somewhere or not properly connect on one end?
05-11-2018, 04:07 PM | #5 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
Seems like the 'ole <12.5 volt battery scenario to me. Rarely see any electrical gremlin pop-up on these pages that doesn't eventually come back to a bad battery from 10-12 era.
As they are a dealer, they should just try a new\newer battery to determine. |
05-11-2018, 04:26 PM | #6 |
The battery was changed like a couple years ago. Y’all don’t think they checked the battery at the dealership? Have you guys seen the videos I posted?
05-11-2018, 04:49 PM | #7 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I would say battery or ground problem.
Those fix 95% of all electrical gremlins.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
05-11-2018, 04:52 PM | #8 |
Just saw them. They didn't pop up the first time I replied. I'm not entirely sure how that relay is wired underneath but something tells me that either it's not getting the correct voltage or there's a short somewhere in that circuit.
I've never looked at that part of our cars but is it possible for you to trace the cables connecting to that relay?
05-11-2018, 05:41 PM | #9 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
My guess is a bad ground.
Did you install a CAI and move the ground cable? Evidently these cars are VERY sensitive to ground connections. |
05-11-2018, 07:06 PM | #10 |
Btw the videos where taken before they replaced the ECM and fuse box
05-11-2018, 07:07 PM | #11 |
ultracrepidarianism
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport Join Date: Mar 2014
GOOD LUCK FINDING OUT
05-11-2018, 07:12 PM | #12 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
I would call the service department and see if they have load tested the battery just to be sure.
05-11-2018, 07:24 PM | #13 |
If they replaced the parts you listed I'd say you've got a bad ground . Check around the engine bay. There was a post about someone having starter issues due to heat ,but turned out to be a bad ground . Granted your issue isn't heat but it is still a starter issue.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
05-11-2018, 09:30 PM | #14 |
Any CEL(s)? or any historical DTC codes?
