03-02-2017, 05:59 AM | #1 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Should I Upgrade Ground Cable?
I was talking to someone on here about slow starts because of starter heat-soak on a warm engine and one of the tips he told me is to change the ground cable in the trunk to a thicker one. What exactly does this do and should I do it? Also can someone send me a link to what I should get?
Pity a man in familiar places, who yet feels like a stranger.
03-02-2017, 06:40 AM | #2 |
Drives: 2012 SS L99 Converible Join Date: Mar 2016
My SS turns over slow all the time. I plan on replacing the battery with a better one
03-02-2017, 06:53 AM | #3 |
Battery is new
03-02-2017, 07:07 AM | #4 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Mine has turned over slow since day 1. I guess I've never heard anyone else's SS start, so I have nothing to compare it to, other than other vehicles I've owned in the past.
I assumed it was normal.
03-02-2017, 07:14 AM | #5 | |
The increase in cable size allows for a greater current carrying capacity. When the starter motor heats up, the copper windings that make up the motor and field circuits increase in resistance, meaning you would need to supply more current to the starter to get the same performance when the starter is cold. It's not the cheapest option, but a high torque mini-starter, such as the PowerMaster XS Torque series will solve all of your heat soak issues. If the issue is just a weakening battery, nothing will fix that other than a replacement battery. Good luck! -Scott |
03-02-2017, 10:32 AM | #6 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Have you checked the terminals at the starter?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
03-02-2017, 11:07 AM | #7 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Still chasin this one huh? Just askin did you chase down and clean every ground connection..in the car? Heat soak on a ground cable..in the trunk? Only reason would be if that cable was damaged/kinked some how..did that happen?
Lol..still no sig with your specs..It would make things easier when peeps respond with legit suggestions...just sayin... FYI...when I upgraded my stock ignition wiring with a MSD harness upgrade, I tapped off the hot on the engine compartment..and that connection was also a bit corroded which I cleaned off...so you may want to check that also..good luck...peace out..
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
03-02-2017, 03:44 PM | #8 |
Not really chasin it because I know what the problem is. I changed the starter myself at the beginning of this year and that solved everything perfectly fine for a few weeks but now the problem has come back. Funny how I made a thread before I changed the starter asking if I should get one of those high torque ones and everyone told me no need to spend a lot of money and OEM is better even though aftermarket doesn't cost that much more.
03-02-2017, 09:03 PM | #9 |
Drives: 2011 2SS Join Date: Aug 2014
After my car was tuned it stopped turning over slow. Might have something to do with timing while starting. Not sure. I also have a good AGM battery
03-03-2017, 09:37 AM | #10 |
Drives: 2014 2SS/RS Join Date: Dec 2014
Do you have header pipe mod that runs near the starter?
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
03-03-2017, 10:56 AM | #11 | |
Also, check your grounds from engine to chassis. I found one that wasn't on the block and it also helped with my starting problems. It was even starting to weld itself to the bolt holding it. Clean them up and apply a bit of dielectric grease. If you go with the high torque starter I hope you check/clean the connections because those aren't cheap. Good Luck. Edit: Check this out. Someone else found a bad ground on their engine and starting has been perfect ever since: http://www.camaro5.com/forums/showpo...5&postcount=48
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 03-03-2017 at 11:14 AM. |
03-03-2017, 11:27 AM | #12 |
Ben Rakers
I used to respond to this guys posts, but he never seems to want to listen to advice from anyone who has had similar problems, must be a certified internet mechanic! lol good luck homeless man.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g |
03-03-2017, 12:46 PM | #13 |
What are u talking about I always listen to people's advice on the forum and private message with many people. Don't have anything useful to say don't bother posting on my stuff
03-03-2017, 03:43 PM | #14 |
Mine turns over slow all the time. It has nothing to do with the temperature of the engine.
Thread Tools | |
