10-21-2016, 01:40 PM | #15 |
Drives: 2012 1LT Drop Top Join Date: Oct 2013
Keep it simple. Battery is new so next culprit would be the alternator. Should be 13.5 - 14.5 vdc with the car running and loaded up, (lights and A/C). After that next guess would be starter.
10-21-2016, 01:41 PM | #16 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
So I just look at the voltage gauge cluster while I'm starting it?
Pity a man in familiar places, who yet feels like a stranger.
10-21-2016, 01:43 PM | #17 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
Look at it while it's running, should be slightly above 13 volts (about 13.5)
10-21-2016, 01:47 PM | #18 |
Drives: Miss Con Ception Join Date: Aug 2016
10-21-2016, 02:16 PM | #19 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I had similar problems... replaced my starter and these problems went away. Someone also mentioned a grounding issue, which could also be your problem.
http://www.camaro5.com/forums/showthread.php?t=464447 eta; Mine did Scenario 2 once. Felt and ran very rough. Shut it down... waited a bit, then it barely restarted but all was normal after it was restarted. Again, issues you're calling out are very similar to mine... except mine never refused to start. |
10-21-2016, 03:46 PM | #20 |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
10-21-2016, 04:25 PM | #21 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
10-21-2016, 05:09 PM | #22 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
http://www.camaro5.com/forums/showth...ranking&page=3
Post 31, could be another possible culprit. I've had this problem one time about 3 weeks ago after having made stops at 3 different stores. After the 2nd stop the car turned over slow but it started and ran fine, after the 3rd stop it cranked really slow and I got the same exact result as you(let the car sit for about 10 minutes with the hood up and it started). Haven't really pursued the problem as if I know I'm going shopping I drive the Jeep so I'm never making frequent stops like that in the Camaro. From everything I've researched you can get the battery tested(there have been cases where they test fine but actually have a dead cell), install high torque starter, check all engine and battery grounds(have seen problems from a loose bolt at the engine to corrosion on battery terminal), or the fix above. I've read people on these forums having the same problem as you and each of those options has cured it for at least one person each. Hope something out of this will help you out.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
10-21-2016, 05:30 PM | #23 |
10-21-2016, 06:15 PM | #24 |
10-21-2016, 06:46 PM | #25 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Yes I have always found batteries truly only live about half of their warrantied life with the advertised CCA, and many go down rapidly toward the end of their life as many are all made the same place just a different brand. I replaced my starter 6 mos or so ago and battery and sanded the ground points up by the starter / frame rails of front cradle and where the battery grounds in the trunk in the threads of a bolt hole which is lame that's no washer no wide area of contact with a plastic piece of the wiring harness attached as you tighten it down to act as a loom, its starting fine now but had a slower starter wind up and problems after about 10k with headers over two years on a 13.
Heat soak can happen as the heat shield is small and just insufficient. Headers on cars are also notorious for shorting starter lives. Good Luck
10-21-2016, 06:54 PM | #26 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
+1 on check battery even if new...what kind is it? is it AGM design? As stated due to high comp ratio cranking CCA on these motors are high and can eat a sub standard batt...and clean all grounds...good luck..
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
10-21-2016, 06:56 PM | #27 | |
10-22-2016, 08:18 AM | #28 |
Drives: 2011 2SS Vert Join Date: Jun 2015
Check the + and - wires on your battery. Make sure the crimps are good. Had this exact same problem on my 2009 GMC and 2012 Cruze. Bad + wire on the GMC and a bad - wire on the Cruze.
2011 2SS
