11-24-2010, 12:49 PM | #15 | |
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda Join Date: Jan 2010
I have a set and I have been debating on installing them myself or having a shop do it. i was told 4 hours for install time. Does this sound right? Also, is the install pretty straight forward or are there any things that should be pointed out? |
11-24-2010, 01:13 PM | #16 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
You can do the job yourself, if your handy with tools. You'll need to raise the car to get under it. Make sure your car is cold, the cats will hold heat for a very long time if you run your car first. I would suggest when putting them on, start all the bolts first, including the cats and exhaust before tightening them up. The hardest part is tightening the cats back up, because there is very little room to work. I didn't bother unhooking the battery, because I didn't want to go through resetting everything. After putting a heat cycle through them, re-tighten the bolts again. Also wipe the headers off with a clean rag before starting the car the first time. Make sure you bend or tie back any lines or wires away from headers so they don't melt. Four hours is about right taking your time and doing a good job ...
Good Luck ...
11-24-2010, 02:01 PM | #17 |
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10 Join Date: Jun 2010
First of all do you have a good torque wrench? If not I know where you can get a good one for free.
11-24-2010, 02:31 PM | #18 | |
Drives: 2011 ss camaro Join Date: Aug 2010
10/28/2010 got it
11-24-2010, 02:34 PM | #19 | |
i didn't kill the cat, put up the sign or even take the picture. i'm a peace lovin dove if there ever was one.
10/28/2010 got it
11-24-2010, 02:42 PM | #20 |
i'm good with tools and have a couple torque wrenches, but with all the health snafu's i've been through the last 7 months i'm afraid if i got under the car...i'd never make it back out.
hell, 5 years ago i'd change out an engine by myself.
10/28/2010 got it
11-24-2010, 02:51 PM | #21 |
Drives: 2013 IOM ZL1 Join Date: Nov 2009
[QUOTE=SlingShot;2577718]What pipes are you running with them ?
The rest of the system was stock. |
11-24-2010, 03:14 PM | #22 |
looks great
11-25-2010, 01:16 AM | #23 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Made my day looking at those bad boys installed!!
Yeehaw! Ivan @ Southwest Speed |
11-25-2010, 02:45 PM | #24 | |
Drives: 2010 IOM 2SS/RS Join Date: Oct 2008
I wonder how much of that low end resonance comes from the CAI. I think that's the exact sound that I'm after in that video. |
11-25-2010, 08:39 PM | #25 |
That's pretty much all exhaust you hear. I have an Airaid on mine, and you don't hear it until I really kick it. Then the whole system comes alive and makes a lot of noise, from the back and front ...
11-28-2010, 10:33 PM | #26 |
Airborne Pathfinder
Drives: Camaro ZL575 Join Date: Nov 2009
those look great, I have been debating myself on these. I have an A6 and while I want more HP I would be content with a lot better pull/quickness.
2010 Camaro Indy 500 Pace car, LS3-ZL575
Other cars are- 95 BMW 325 sedan- AA exhaust, AA CAI, AA Strut bar, AA chip, M3 rotors and calipers, racing clutch, oversized injectors, upgraded M3 interior- Audi A4 SLine, with black out optics |
11-28-2010, 11:03 PM | #27 | |
You really start seeing nice gains with the addition of supporting items. Alone they aren't worth more than a handful of ponies, but when used in conjunction with other modifications that contribute to the overall efficiency of the entire "air pump" mentality, they are great. Really nice down low Torque gains! Ivan |
11-28-2010, 11:13 PM | #28 |
Drives: 2012 CTS-V Coupe & 2SS/RS Join Date: May 2009
I also have the DT Shorties on mine and love them ! !
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Camaro Dove Tail Spoilers Compilation | daphatgrant | Cosmetics and Lighting Modification Discussions | 470 | 10-28-2020 02:35 PM |
Check Engine light on after ARH and Pipeline CAI installed | se7en | Tuning / Diagnostics -- engine and transmission | 17 | 03-10-2010 08:06 AM |
Doug Thorley Shorties Installed | WadeWilson | Camaro Photos | Spyshots | Video | Media Gallery | 15 | 12-13-2009 06:45 PM |
Another Dealer Installed Stripe Problem | 69er | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 07-13-2009 03:32 PM |
Factory Striping vs. Dealer Installed | RetroDude | Cosmetics and Lighting Modification Discussions | 1 | 04-23-2009 01:01 AM |
