Old 10-06-2019, 11:55 AM   #29
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Looks like the welder was out of shielding gas or some other issue that contaminated the weld, it was the welds that caused the issue obviously...
DaveC113 is online now   Reply With Quote
Old 10-06-2019, 11:58 AM   #30
DaveC113
DaveC113's Avatar
Originally Posted by Broadway View Post
I am having same issue with my car, although my bracket didn't come completely off like yours, just cracked along the aft end of the right weld. Got a terrible rattle and exhaust leak. Took it to the dealership in May, they said they had to order new bracket. They still haven't gotten it in yet, or done anything. Called GM customer support to see if they could expedite the process or help in any other way, and they have been basically useless
Yeah, that bracket can't be replaced by it's self, the material around it isn't sound to weld a new bracket to. The entire exhaust needs to be replaced.
I'd go into the dealer and speak with the service manager face to face. They need to order you a new exhaust and install it ASAP.
Old 10-06-2019, 12:11 PM   #31
Broadway
Drives: 2018 Camaro SS
I have doubts they are going to replace the entire exhaust, they seem to have been trying to blow me off concerning this issue.
Wondering if there would be any benefit of just getting after-market midpipes to replace that section. I have an auto with NPP, so I don't want to change too much and deal with AFM issues and CELs
Broadway is offline   Reply With Quote
Old 10-06-2019, 12:19 PM   #32
DaveC113
DaveC113's Avatar
IMO, no benefit to aftermarket exhaust on these cars at all, besides sound. Most of them make the aerodynamics far worse actually... that big-a$$ suitcase is also there to keep your rear bumper from acting like a parachute.
Your car has a warranty, I'd be insisting they fix it.
Old 10-06-2019, 02:43 PM   #33
Broadway
Now, I wouldn't mind a more aggressive sound, lol.
But yeah, the whole reason I haven't just taken it somewhere else to get this fixed is because of the fact that I got a new car with a warranty so I wouldn't have to do that type of thing.
Old 10-06-2019, 11:22 PM   #34
Mountain
Mountain's Avatar
Probably 409 stainless, which is fairly standard on today’s automotive exhaust. This is a VERY odd failure, being both pipes.
Old 10-07-2019, 10:34 AM   #35
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
What I could see as going on here is that there might be something wrong with the welds? Maybe there is some kind of contamination problem (wrong spool of wire used, problem with the shielding gas during the weld) that would allow corrosion to begin, then over a little time cause the welded metal to corrode?
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
DorkMissile is offline   Reply With Quote
Old 10-07-2019, 11:24 AM   #36
Mountain
Mountain's Avatar
Good thought!
I know when I've welded exhaust stuff, you can 100% get a failure like this with the wrong fill wire and/or excessively large heat-affected zone.
Old 04-22-2022, 06:34 AM   #37
zedobone
Drives: Camaro 2SS
Originally Posted by GP86 View Post
Final update on this for those who are interested. The dealer, Suburban Chevrolet in Ann Arbor, Michigan completely ghosted me on this. They never returned my calls and never offered any kind of fix. I've been unhappy with every other service they provided on my car, so I expected nothing less.
I found a local shop who cleaned it up and re-welded the original piece back in for $80.
Hi, I had recently the exact same problem on a SS19 with 15k kms. The solution was basically the same, the dealer re-welded.
Did it solved the problem permanently or did it happen again? Just curious on how long will this last.
zedobone is offline   Reply With Quote
Old 08-08-2022, 11:01 PM   #38
Karld
Drives: 2016 Mosaic Black 2SS Convertible
Gen 6 Exhaust
I had the same thing happen to me. I have a 2016 2SS convertible. Driving about 65MPH all of a sudden it sounded like something hit the underside of the car. Car ran fine, got home lifted it and found 2 hole blew out. Nobody could tell me what caused it and just had a local muffler shop weld in new pieces
Karld is offline   Reply With Quote
Old 10-25-2022, 07:15 AM   #39
zedobone
Drives: Camaro 2SS
Mine was rewelded 6 months ago, and I can already see the black spots coming up again...
What's your experience, how long did the welding last?
Cheers
Old 10-27-2022, 02:37 AM   #40
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
Former Ann Arborite here. I'm still up in MI frequently. Have always had good luck at Greg Bell Chevrolet in Adrian MI. 30 mins south of AA. Suburban is great for parts but not my go to repair folks.
Val Walkinshaw is offline   Reply With Quote
Old 10-27-2022, 05:21 AM   #41
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
That is some kind of metal fatigue. Looks to me like the heat from when the pipe brace was welded changed the properties of the pipe metal. Add in repeated heat cycles and eventually the metal cracked and failed.
Spaceme1117 is offline   Reply With Quote
Old 10-27-2022, 07:44 AM   #42
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Go to a good exhaust shop, have those cut out and weld in new pieces.
