05-23-2020, 10:56 PM | #29 |
2020 Shadow Gray 2SS
I just did my 2nd diff fluid change today (at 1,500 miles, first was at 505 miles)... A little bit of "smudge" on the magnetic plugs but overall the fluid looked great... I'll probably do the differential every other oil change going forward (every 5000-6000 miles)...
Yes, it takes about 1.2 qts (2SS with LS Differential)... Super easy to change... Get a fluid pump from Amazon...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
05-23-2020, 10:56 PM | #30 |
Long hauler
I’ve got 84k miles, idk about the first 61k but I haven’t touched the it. I hear the smell is awful so that’ll be fun
05-23-2020, 11:07 PM | #31 |
some people are lucky or it was changed and they didnt know it. in the 5 new sets of gears iv owned they were all dark metallic black at 500. 2 new Camaro SS 2 new Silverados. All V8s and id count my 12 Camaro twice because i put 3.91 gears in it.
05-23-2020, 11:16 PM | #32 | |
Mine at 505 miles as well as at 1,500 miles (today) both looked damn near new, slight discoloration and some "smudging" on the magnetic plugs, but overall looked very good... Cheap insurance to change it...
05-24-2020, 08:25 AM | #33 |
Drives: 2020 Camaro LT1 Join Date: Feb 2020
For someone who doesn't track and just uses it for street use would you guys consider it ok to wait? The dealer said about 30-40k unless I hear groaning. In my current handicap and medical situation (walk with a cane cause bad lower back and left leg) I can't really do these things like I used too. My car is at 1475 miles and I got it in late February. After I get to the 1500 mile break in it will probably be driven about 100-300 miles per month with the winter months being much much less if any miles driven at all. This is my first Camaro and I want to take care of it for a long time. EDIT: I did check some local places and my dealer was actually the cheapest to provide the service believe it or not.
05-24-2020, 10:48 AM | #34 |
Drives: 2019 1LE Join Date: Nov 2019
Fluid
At 600 it was black, much better at 1923 miles but a bit dark.
"That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle"
05-24-2020, 11:52 AM | #35 | |
Wow, mine at 505 miles still looked damn near new (as did it at 1,500 miles), I'd be concerned with diff fluid that black after only 600 miles...
05-24-2020, 12:19 PM | #36 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
Isn’t it possible that the darkness is caused by assembly grease, like molybdenum disulfide from the assembly process? I mean it would make a lot of sense if it took a couple of flushes to get it all out.
05-24-2020, 12:25 PM | #37 |
No idea but my 2SS diff fluid looked damn near new when I drained it at 505 miles as well as again at 1,500 miles... A little smudging on the magnetic plugs but that was about it...
05-24-2020, 12:55 PM | #38 |
Drives: 2019 Camaro SS Join Date: Jan 2017
Just had mine changed at 700 miles or so. Clean and clear.
2019 Camaro 1SS. Crush. Mishimoto Catch Can, BMR Strut Tower Brace, Oracle Side Markers, ZL1 Side Skirts, Blade Spoiler W/ZL1 Addons Wicker Bill, Exhaust Cut Outs, BMR Front and Rear Cradle Braces, Cold Air Inductions CAI. ZL1 Rims 285 Fronts and 305's Rear. Speed Inc Tune PCM & TCM.
05-24-2020, 07:52 PM | #39 |
Drives: 2023 SS 1LE Join Date: Mar 2020
E Diff drain plug at 5k miles. 18 SS 1LE... You be the judge..
05-25-2020, 05:43 PM | #40 |
Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
I did mine at 17K miles. Easy to do, and fluid was not all that dirty which surprised me with very little metal on the drain plug magnet.
05-25-2020, 07:05 PM | #41 | |
05-25-2020, 07:38 PM | #42 |
There's clutches in there, no matter how many times you change it, every time you change it it's going to be darker with some metallic residue in it. If it ever comes out Crystal Clear, then it probably means your limited-slip is shot. :-)
