Old 04-13-2024, 05:10 PM   #1
iwk2much
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD
Manual Tranny
My manual transmission bearing i making a racket. When I engage the clutch, the noise subsides. Sounds like the bearing races are pitted.
Can these be serviced / changed? Any input from the experts appreciated.
iwk2much is offline   Reply With Quote
Old 04-13-2024, 07:14 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Throw out bearing needs replaced most likely.
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-14-2024, 05:38 AM   #3
iwk2much
I left that part out. I just had that replaced. Noise didn't go away.
Old 04-14-2024, 07:46 AM   #4
nighttowl
nighttowl's Avatar
Did you change the clutch or pressure plate? When the throw out, bearing was replaced. Also, was it an oem throw out bearing or something else.
Old 04-14-2024, 04:08 PM   #5
iwk2much
yes, on my 3rd clutch and pressure plate. pretty sure it is the tranny bearing, just dont know if it cam be replaced
Old 04-15-2024, 11:51 AM   #6
nighttowl
nighttowl's Avatar
I see.
It can be fixed if you can find someone who is willing to repair the transmission.
Most places are only interested in replacement when a transmission needs repair.
Old 04-15-2024, 02:03 PM   #7
iwk2much
I see.
I don't see any Transmission parts available in the GM parts websites. I would hate to drop $7K on a new tremec unit if the worn out part is replaceable.
What have other done when needing a replacement manual tranny?
Old 04-15-2024, 02:46 PM   #8
Mark R
Drives: 2018 ZL-1
Three clutch and pressure plates? How are you driving your car? That's a lot of replacing going on down there...
Old 04-15-2024, 04:34 PM   #9
nighttowl
nighttowl's Avatar
Most of the time if you need a transmission, you'll either nwed to contact a salvage place or look online at places like ebay.
For parts, do a search for tremec parts and there are a bunch of places that repair them.
You can get individual parts from Tremec.
Old 04-16-2024, 04:53 AM   #10
iwk2much
The first clutch replacement (2nd clutch) I feel was an installation issue causing premature wear. The car is 100% a track car now but I don't feel I am harsh driver, shift are still on point, just noisy as heck when idling.
