06-24-2020, 09:13 PM | #1 |
Drives: 2018 Camaro SS Join Date: Sep 2018
Widest Tire on Stock SS Rim
search wasn't working for me, apologies in advance
what is the widest tire front and rear you can go on the stock 2018 SS rims? i have seen 295/35-20 rear and 255/40-20 front |
06-24-2020, 09:16 PM | #2 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Safest is 255/40 and 285/35. People have run 305/30 on the rear.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
06-26-2020, 08:29 AM | #3 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
What you can fit and what you should fit are two different things. For example, you can fit a 305/30/20 on 9.5 wheel, but that is outside the rim width recommendations for that tire. You can find those rim widths on lists of tire specs, and you should follow them.
Matt Miller
2020 SS 1LE |
07-03-2020, 04:28 PM | #4 |
Drives: '17 SS 50th Camaro Join Date: Apr 2012
How far is the speedo off in the 255/285 setup?
2017 50th Anniversary 2LT\RS - #1583 SOLD
2017 50th Anniversary 2SS - #3410 |
07-04-2020, 06:16 AM | #5 |
Any reputable shop won't put a 305 on a 9.5" wheel, too, with that width on a narrow wheel you're not getting the tread footprint you would on a properly sized rim any way.
07-04-2020, 08:58 AM | #6 |
1.1% (when speedo shows 60, real speed is ~60.6)
07-04-2020, 09:04 AM | #7 | |
(With a narrower profile tire, as not all tires have the same physical shape even in identical sizes, one might go up to 265 and 295, respectively, but at that point diminishing returns kick in, plus the front tire may start rubbing against the spring perch or at least the outermost nipple, there isn't too much clearance. Not worth it IMO, if you want wider tires, you need to surrender to the need for matching wheels.)
