06-15-2020, 07:05 PM | #1 |
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
1le camaro suspension upgrade
Started to do ax and and curious if anyone with the ss/1le have done any upgrades on their suspension and what they went with. Everything I keep finding is for the normal ss to get it like the 1le. I will be doing a mix of ax and drag. My last event the car would take a sec to turn like it was abrupt and then would yank.
2019 ss/1LE d1x, LT4 fuel System, Triple meth nozzle, ported BTR, 2” Texas speed headers, Built 377 SPDC motor, CTporting heads, TooHighPsi port system, SMG aux.
1014/800 on E55/meth 890/750 on 93/meth Working on tuning the port system for full e. With questions just message me here for a faster response. https://www.facebook.com/eric.willia...ibextid=LQQJ4d |
06-15-2020, 08:54 PM | #2 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
The only thing you need to complete the SS 1LE is solid rear cradle bushings and a track alignment. Leave everything else alone, GM nailed the set-up on it.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-16-2020, 07:17 AM | #3 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
For autocross competition the key to answering your question is what class you plan to run, and what mods they allow. If you're in SCCA classing, then stock your car goes to B Street. That allows you to change one sway bar, and most people swap for a stiffer and/or adjustable front bar to tame the slight power-on oversteer the car can have with full-bore alignment and all nannies off. I went with the BMR front adjustable bar because at its softest setting it's very close to stock, which seems like desirably option to have.
If you want to start modding for real, then consider CAM-C. I have a list of mods I'd do there (to remind myself why I don't want to go to that class!), and I'm happy to share if you want. My advice to someone just starting out is to compete for a season and use that time to gain skills and also to assess what class you really want to choose, and then plan your mods accordingly.
Matt Miller
2020 SS 1LE |
06-17-2020, 06:18 AM | #4 |
Drives: 2019 2SS 1LE Join Date: Aug 2019
Or you could do like me and run whatever mods you like in an entirely uncompetitive class. I was never going to win a national championship, so I'm really doing it to have fun and get better against myself.
I found the suspension to be good enough at handling body movements that I didn't have a desire to mod it yet. I put in a skip shift eliminator, BMR cradle lockouts, and braided lines, all of which take me out of B Street. The OE Supercar 3 tires are great at coming up to temp quick, too. Edit: there's supposedly an E-LSD calibration update you can have flashed at your local dealer to have the diff lock and unlock more quickly at low speeds. Looking forward to having it flashed and trying the new calibration. I have found some one wheel peel situations early in the day. Last edited by cmfhsu; 06-17-2020 at 06:29 AM. |
06-17-2020, 07:33 AM | #5 |
Just a quick clarification: I don't think the skip-shift eliminator alone takes you out of Street classes.
Matt Miller
2020 SS 1LE |
06-17-2020, 10:33 AM | #6 |
yyz springs
06-17-2020, 08:04 PM | #7 | |
I run in CAM-C anyway, so it doesn't matter hugely to me. I just go hog wild |
06-17-2020, 09:44 PM | #8 |
13.10 ENGINE AND DRIVETRAIN
J. On cars equipped with computer-aided gear selection or “skip-shift” features from the manufacturer, modifications to defeat the “skip-shift” feature are permitted any may serve no other purpose.
Matt Miller
2020 SS 1LE |
06-17-2020, 11:49 PM | #9 |
Drives: 2018 Summit White 1LE Join Date: Oct 2019
Does a CAI move you out of B Street?
06-17-2020, 11:54 PM | #10 |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
