06-06-2020, 11:14 PM | #1 |
Drives: evalanche Join Date: Aug 2019
Lowering springs install
Lowering the car today and am done with 1st front wheel, almost. I have everything installed ready to go back together BUT the sway bar end link for some reason doesn't line up with its home. Its not even close. I'm talking about the fastener end of the link lining up 3-4 full inches ABOVE its home location on the strut.
I then blew lightly on her clit, and she moaned, "Don't be a tease!" I licked my lips and then flicked my tongue out, licking hers. I ran my tongue up through her wet flesh, savoring the taste of the sticky fluid gathering in my mouth. When I reached her clit, I circled it and then gave it a soft kiss on webcam chat - https://sexchat.bar Sam moaned and jerked her hips, pushing her warm, wet flesh into my face. I worked back down the length of her *****, enjoying the way her thighs trembled beneath my hands and the soft moans coming from her as I swirled my tongue through her wet lips. I forced myself to not attack her ***** the way I wanted to and took my time exploring her with my tongue. Sam was whimpering softly, but not telling me to go faster. I pushed my tongue against her and slid down the length of her *****, shoving it inside her. Last edited by rothayato; 07-30-2020 at 10:34 AM. |
06-07-2020, 02:26 AM | #2 |
Drives: 2017 Camaro 2SS Join Date: Jan 2020
I took another jack and lifted the knuckle to match the height to the end link.
2017 Camaro 2SS 6MT
06-07-2020, 09:40 AM | #3 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Make sure you've got both wheels on the same "axle" (i.e. both front or both rear) off the ground at the same time. Might also need to install the opposite spring before reinstalling the the roll bar connecting link. Using a jack to compress the spring could also be done but isn't as ideal as getting rid of the left vs. right suspension height difference via unloading the compressed side. This thread might help explain: https://www.camaro6.com/forums/showt...php?p=10489727
2017 SS 1LE.
06-09-2020, 09:58 PM | #4 |
one jack under the body at full droop for the spring to be uncompressed to remove. Another jack is necessary to compress the lower control arm to get the sway bar end link to align and bolt up after the spring is reinstalled
06-12-2020, 08:44 PM | #5 |
Just finished Eibach's and Bilsteins on my SS. When you get to the rear, I pulled the inner lower control arm bolt instead of the outer because I couldn't get it to clear the ebrake cable.
07-06-2020, 03:49 PM | #6 |
Drives: 2017 Camaro SS/ Nightfall gray Join Date: Sep 2016
I also did mine last month with yyz springs. I had that problem too. I just used the jack to raise it up and align the holes. Aligning the holes on the low and trailing arms were also a pain in the ass, lol. I used a screwdriver to stick through the holes and pry the holes to line up.But it’s doable, just patience
Ported Tsp heads,Pray stg2 cam, Ported MSD, Ported 95 TB, 2" headers, Roto-fab dry, e-85, full exhaust.
