04-21-2021, 07:27 AM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
ONE WAY CHECK VALVE
Hey guys. anyone have a part# or place where you bought a one way check valve for the pcv system? Trying to get through this supercharger install and the one that came with the kit is far to small. Thanks
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
04-21-2021, 09:32 AM | #2 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
I got mine with the catchcan. But I'm sure you can find one from summit or jegs. If you cant let me know I think I have another I can send. I'll have to check.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
04-21-2021, 11:21 AM | #3 |
Thanks man. I found them on line. One of my employees has a bunch, but they were plastic. I was a little worried at first, but its states they are high pressure parts and they are used in air, fuel ect applications so should work
04-21-2021, 11:24 AM | #4 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Mine is plastic and was pretty cheap so I bought three just in case they did not last. I still have the two spares in the parts bin.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-21-2021, 12:46 PM | #5 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
04-21-2021, 03:13 PM | #6 |
Great to hear!
04-21-2021, 03:14 PM | #7 | |
