04-02-2020, 07:43 AM | #15 |
As noted, the only differential gear swap shorter than your existing 3.73 would be very expensive.
However, there are different gearsets made for the M6 trans. Your SS should have a 0.74 fifth gear and a 0.50 sixth gear. The ZL1 has a 0.82 fifth gear and the ZL1/1LE has a 0.68 sixth gear. So you could change the overall ratio in top gear to be shorter (more rpm) if you wanted to, don't know what the cost would be, and you'd need to tune it for either a differential swap or a gear swap. |
