12-02-2016, 06:30 PM | #1 |
Drives: Blaze Red 2014 2SS/RS Join Date: Sep 2016
Noob with a question....
I own a 2014 2ss/rs that as far as I can tell by my build sheet that it is loaded with all options it has the strut brace, stiff suspension, brembos ,performance sticker on the top of the rad. support etc. My question is it does not have the performance exhaust is this because it has an auto transmission or is the only option that was not ordered on the car....I bought the car in June used it only had 2800 miles on it
12-02-2016, 07:13 PM | #2 |
Drives: Miss Con Ception Join Date: Aug 2016
Welcome!
The NPP exhaust was never offered on the L99 because of the AFM.
2011 1SS/RS LS3 CGM
12-02-2016, 09:53 PM | #3 |
Drives: 2015 BVM 1SS/1LE Join Date: Aug 2010
You are correct, the NPP is/was a manual transmission LS3 equipped car only option on SS. Otherwise, sounds like you are quite loaded on the options list.
12-02-2016, 10:16 PM | #4 |
Thanx to all who replied.....
12-02-2016, 10:57 PM | #5 |
USA-1
What performance sticker is on the radiator? Is this the first Camaro you've owned?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
12-02-2016, 11:27 PM | #6 |
Drives: '18 SS 1LE Join Date: Jul 2016
12-02-2016, 11:58 PM | #7 |
does it have a sunroof and Navigation? The 2SS is basicly loaded except for dealer installed options.
12-03-2016, 02:14 AM | #8 | |
Sunroof was an option on all LT/SS but you loose the reverse Mohawk and headroom.
2011 1SS/RS LS3 CGM
12-03-2016, 06:05 AM | #9 |
Started#gottalovethatblue
Wow NPP was never offered on an automatic? That's sad. Own an auto, get stuck with crappy sounding exhaust...
12-03-2016, 08:39 AM | #10 |
It has the sun roof the car I believe has every option that was available
12-03-2016, 09:01 AM | #11 |
12-03-2016, 10:29 AM | #12 |
wow...even has the deerhorn mechanics coverall rack option.havent seen that before.enjoy the new camaro...
12-03-2016, 12:58 PM | #13 | |
if he has mylink navigation then he has every option.
12-03-2016, 01:32 PM | #14 |
I have it but I do not subscribe to onstar
