Old 10-08-2018, 11:04 AM   #1
Gator2SS
Drives: 2016 2ss
Opinion on alcohol free gas.. 93 and 98 grade
I understand the difference on e85,87,89 ,93 and 98 grade gas, I also understand the alcohol and alcohol free gas.. I guess i just wanted opinions on usage for daily or trip and long term use... Please expand my knowledge.. Thank you..
Gator2SS is offline   Reply With Quote
Old 10-08-2018, 11:18 AM   #2
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
You mean Ethanol free my friend. Here's all you need to know. Unless you have an E85 specifically tuned vehicle:
- Ethanol basically sucks, and ruins everything if left long term.
- Ethanol free gas is better, ergo more expensive.
- Daily use of Ethanol fuel is okay, but when I store for winter it will be with 100% gas.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 10-08-2018, 11:30 AM   #3
Gator2SS
Drives: 2016 2ss
I have heard it called both so was wondering.. I have both available here, regular gas with ethanol and ethanol free. Does ethanol run cooler.. I will always pay more this car if need be. I guess the thing that is throwing me is that some times old timers are calling it alcohol free, which I figured that would make it run hotter. Reason being alcohol race cars run so much cooler... But build up moisture... ?
Old 10-08-2018, 11:44 AM   #4
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Ethanol burns cleaner so it was mixed with most fuels to be epa friendly. It is also cheap as hell for them to make so they can mix it in and still charge us the same amount and make millions more. My flex fuel sensor reads about 12-13% out of pump 93.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 10-08-2018, 12:32 PM   #5
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
So I will digress on this question.
when storing a vehicle and putting stabil in. do you fill up say 5 gallons? or fill almost full with stabil (both instances) I normally store my car mid October till first of April.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 10-08-2018, 12:42 PM   #6
Skyset
Drives: 2017 Camaro 2SS Coupe
Hahhahha alcohol free
Skyset is offline   Reply With Quote
Old 10-08-2018, 12:45 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Ethanol is only "cheap" due to heavy subsidy used to pay for it.
No subsidy and ethanol would... all but evaporate. Takes more energy to produce than it generates... stupid.
ing for grip.
http://www.motorsportsne.com/
Old 10-08-2018, 06:45 PM   #8
ecko04
Drives: Too many to list
Read the bottle for the correct mix.
In short, you don’t chuck your fuel tank full with 18 gallons of stabil.
Sent from my iPhone using Tapatalk Pro
ecko04 is offline   Reply With Quote
Old 10-08-2018, 07:51 PM   #9
Gator2SS
Drives: 2016 2ss
I'm not storing the car... I want what will give best horsepower over long term and keep motor cool and clean...
Old 10-08-2018, 09:36 PM   #10
Risky Justice
Risky Justice's Avatar
Drives: 2016 Camaro 2SS M6
Ethanol is the proverbial shit. I hear people say it doesn’t make much of a difference on an otherwise stock car, but those people are smoking crack. Night and day difference...and the torque!
My dad’s stock C7 Vette with the 7M made 442/471 and I made 482/503 on a Dynocom. Same day and everything.
Risky Justice is offline   Reply With Quote
Old 10-08-2018, 11:33 PM   #11
Rnovrit
Rnovrit's Avatar
Drives: 2018 NFG ZL1-1LE
I think he meant if you add Stabil to your tank for storage, do you add it to roughly 5 gallons of gasoline in the tank (aka 1/4 tank of fuel) or to a full tank of fuel.
It is best to store a vehicle with a full tank as it lessens the amount and chances of moisture buildup in the fuel tank.
Rnovrit is offline   Reply With Quote
Old 10-09-2018, 08:21 AM   #12
oneredry
HYPER SS
oneredry's Avatar
Thanks for this, this is exactly what I meant. Sorry for the confusion.
Ordered: 1/15/2016
Delivered 03/23/16
Old 10-09-2018, 08:46 AM   #13
DorkMissile
DorkMissile's Avatar
Drives: 18 1SS 1LE HyperBlue
To put it as simple as possible - fuel that is 10% ethanol is like it is 10% "air". Yea, it burns but it provides less power per gallon than the same fuel that is 100% gasoline.
Where I live (Minnesota) you can buy 91 octane that is E10 and non-oxy, the non-oxy makes more power, gets more mileage and runs cooler in my car. However it is hard to find, and it is priced like race gas.
I grew up in Michigan and take a trip there once a year and in my truck the last several years I can fill up at home and drive there, I have to get gas 40-50 miles from my destination. On the way back on non-oxy fuel (easy to find in MI) and I can make it all the way home without stopping. Has happened 7 or 8 times over the years.
DorkMissile is offline   Reply With Quote
Old 10-09-2018, 08:46 AM   #14
ecko04
Once again, the answer is the same. Follow the directions on the bottle that you are using.
For Stabil, yes the directions state to fill it up and then add Stabil, as directed, based on the amount of due on the tank.
Other products, that also work, have different directions.
RTFM and you’ll be fine.
