08-16-2020, 12:50 PM | #29 | |
Drives: 2019 ZL-1 Join Date: Feb 2009
" EDIT: I switched to a Battery Minder 1510- it has a "de-sulfarating mode allows batterys to recover...
2012 Yukon XL Denali w/ 6.2 AWD |
08-16-2020, 01:52 PM | #30 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Have you made any electrical modifications to the car? Even minor changes like switching from OEM to LED light bulbs might cause the Body Control Module to stay awake and that can cause a problem.
08-16-2020, 02:02 PM | #31 | |
Not sure if Teneck83 meant to be saying it was 30 minutes after he removed the battery tender, or after a 30 minutes charge on the tender. |
08-16-2020, 07:24 PM | #32 |
Drives: 2018 SS 1LE Join Date: Oct 2017
30 minutes off the tender. I always leave the car on the tender while parked in the garage
2018 ZL1 1LE
1966 Corvette 427/425 vert 1969 Corvette 350/350 |
08-16-2020, 07:26 PM | #33 | |
It’s bone stock.
2018 ZL1 1LE
08-16-2020, 09:00 PM | #34 |
Chief Bief
Drives: Nightfall Gray Camaro 1SS Join Date: Dec 2015
I've had issues like that lately. Only thing I can say is the taillights I purchased for the car caused it to go dead after sitting for a period of time. It did cause a subtle drain over time and if I don't drive the car for a week or so it will die. I drove across country with the car and back with no issue but seven days and no driving causes a dead battery.
I'm looking into how to prevent this from happening and keep my lights at the same time.
2016 NFG 1SS M6 JLT Intake, LT2 Manifold, LT5 TB, CSP 2" headers, AWE Catback Exhaust, Apex ARC-8 Wheels. 426whp/434wtq |
08-16-2020, 09:36 PM | #35 |
08-16-2020, 09:43 PM | #36 | |
08-16-2020, 10:56 PM | #37 |
That's a fair point, but the originals suck big time... I use the Gen5DIY reverse light harness and the car has no such problems, starts right up even after several weeks, battery voltage is fine and charging works as expected.
08-16-2020, 11:36 PM | #38 | |
Drives: 2SS - Black Join Date: Oct 2009
Procharger D1X
Kinda fast, I guess |
08-17-2020, 02:41 AM | #39 |
I’m on my second battery. An optima yellow top. Second day new battery was in the car, same as before. Brand new, fully charged battery.
2018 ZL1 1LE
08-17-2020, 05:10 AM | #40 | |
Did you verify the new battery was fully charged yourself, or assume it's fully charged because it's new? Did you check the battery voltage (with the motor off) after the battery has been disconnected from the tender for several hours? Regardless, a battery tender alone is not going to fully charge it unless you wait a really long time. Sometimes we make assumptions that make troubleshooting harder. |
08-17-2020, 10:28 AM | #41 | |
08-17-2020, 07:59 PM | #42 | |
If you mean level of charge, 60% is no where near a fully depleted battery. A fully charged, rested battery will read about 12.6 to 12.7 volts. 90% charge is about 12.5 volts. 60% charge is about 12.1 to 12.2 volts, still enough to start the car. A fully depleted battery, 0% charge, will read less than 10 volts, and might crank the car weakly, if at all. How are you arriving at the 60 and 90% values? |
