Old 03-20-2019, 08:51 PM   #1
Lowbird
Lowbird's Avatar
Drives: For sale
Anyone know this 1le?
Hey guys.
While shopping around for a 17 this popped up.
https://www.truecar.com/used-cars-fo...vrolet-camaro/
I contacted the dealer and asked if it was a 1le. They said no. I'm going to ask for a picture of the option sticker. It looks the part at least.
She was in an accident that deployed the side air bags. Carfax says left side and rear damage. Driver Recaro bottom is looking a little off as well.
I'm doing some digging for actual damage. I ran through most of the threads on here of accidents or wrecks.
Kinda hoped the original owner was on here. It was from Maryland.
I'm thinking of calling a local Chevy dealer with a body shop or body shop with good reviews and contracting them to inspect it.
Thanks
-Scott
Lowbird is offline   Reply With Quote
Old 03-20-2019, 09:47 PM   #2
SpazmXylam
Because Racecar!
SpazmXylam's Avatar
Drives: 17 SS 1LE
My initial reaction is that it is a 1LE. Brakes, lip spoiler, and various alcantara interior trimmings (steering wheel, seats, and shifter) all point the right direction. Wheels too but those are easy to swap out. HVAC looks like 1SS trim which is the only choice for a '17 1LE.
Front bumper looks like ZL1 style aftermarket(part of the splitter looks to be peeling off).
In conclusion: strong likelyhood it is a 1LE. Sure fire way to tell is to see if you can access the PTM menu. Standard SS does not have it. Scroll through normal, sport, ice/snow, and stop at track mode. Press the traction control button twice. A new menu should pop up in the middle of the gauges for wet, dry, sport 1 & 2, and race.
SpazmXylam is offline   Reply With Quote
Old 03-20-2019, 10:41 PM   #3
metros11
Drives: 2018 SS 1LE
It's a 1LE for sure, the interior bits give it away. I'd be weary though regarding the damage, price seems very low.
metros11 is offline   Reply With Quote
Old 03-20-2019, 11:04 PM   #4
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
Not just the normal 1LE bits, But it has PDR too. You can see the Bezel for the SD card slot in the lower dash trim panel in one of the pictures.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 03-21-2019, 03:59 AM   #5
JeromeS13
Drives: 2017 1SS/1LE
HUD is also a dead give away on the 1SS.
Old 03-21-2019, 08:50 AM   #6
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
Depending on how interested you are I would stop contacting that dealership specifically regarding the 1LE package (since it is a 1LE). However, I would continue to pursue the previous damage.
The front bumper looks absolutely horrible.
The tires look stretched? I'm guessing they forced 275's over the factory width rims.
If the vehicle did suffer significant damage were the wheels replaced? Did they use OEM forged wheels or aftermarket repro's? Does it have a mixed set of wheels now (half forged OEM half cast aftermarket)?
The paint looks terrible from the pictures.
Travel with caution! At a minimum you're looking at having to repair or replace the front splitter, tires if they are indeed the incorrect size, and a significant paint correction. Oh, and you'll have to remove the half gallon of Armor-All they've covered the interior with.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 03-21-2019, 10:47 AM   #7
MattZ28
Drives: 2017 SS 1LE, 2006 S2000
Looks like a 1LE that sustained front end damage considering the hood wrap is missing and front bumper is not original. I'd avoid it.
MattZ28 is offline   Reply With Quote
Old 03-21-2019, 10:52 AM   #8
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
1le with a fake zl1 front end? lol meh
Old 03-21-2019, 11:42 AM   #9
KCelsius
KCelsius's Avatar
Drives: 2018 Summit White 1SS 1LE
Can confirm it's a 1LE looking at the vehicle build sheet.
I'd be a bit careful with this one with the accident damage, probably want to get it inspected and looked at thoroughly.
Also, some of the work done in the "maintenance inspection" on 6/8/2017 and 8/5/2018 were:
6/8
Cause Code: 4061-Interface (Gasket, Seal, Hose, Weld..) - Leaks
Labour Op 4062410-Valve Lifter Replacement - Left Side
8/5
Cause Code: 3051-Rotating Part - Worn/Stripped
Labour Op 3040270-Rear Wheel Drive Shaft Replacement - Right Side
KCelsius is offline   Reply With Quote
Old 03-21-2019, 11:55 AM   #10
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Rode hard and put away wrecked?
'18 1SS 1LE Black, PDR
Old 03-21-2019, 12:46 PM   #11
JayhawkSS1LE
JayhawkSS1LE's Avatar
Drives: 2017 SS 1LE
If interested...I have a ‘17 1LE in the for sale section. 4600 miles, never tracked, always garaged, PDR. Full Borla catback with carbon fiber tips and NPP.
17 SS 1LE.
JayhawkSS1LE is offline   Reply With Quote
Old 03-21-2019, 12:46 PM   #12
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
That's a new one lol.
2018 1SS 1LE
Old 03-21-2019, 02:25 PM   #13
Matos1LE
Drives: SS 1LE
That poor car, it has that goofy, Angry Birds edition, ZL1 "style" bumper from American Authority. Definitely a real 1LE, just not one I would recommend buying. Something looks off about the wheels and it isn't just the tires either, they might be repros.
Matos1LE is offline   Reply With Quote
Old 03-21-2019, 05:22 PM   #14
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
I thought the same thing. The tires look sooo stretched.
2018 1SS 1LE
