Old 03-17-2019, 08:08 AM   #1
artey34
artey34's Avatar
Drives: 2018 Camaro 2SS 1LE - Hyper Blue
What oil to use
Almost time to pull the car from storage which means it will need an oil change. My last 2 were 5W-30. This year, I plan to get a few track days in but mostly daily driving. Should I switch over to Mobil 1 0W-40 ESP? Is Amazon a good place to get this?
artey34 is offline   Reply With Quote
Old 03-17-2019, 08:15 AM   #2
Move_Over
Drives: ISO ss 1le
There’s a big booklet in the glove box that lets you know what oil to use
Move_Over is offline   Reply With Quote
Old 03-17-2019, 08:25 AM   #3
artey34
artey34's Avatar
I know there was a change from 2018 to 2019s so the new recommendation is not in my book
Old 03-17-2019, 08:38 AM   #4
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Why not, Amazon or eBay have it fairly priced. I purchased two cases a few weeks ago on eBay for $49ea and free shipping.
Warrior102 is offline   Reply With Quote
Old 03-17-2019, 09:44 AM   #5
Gasoline_Farts
Drives: 19 SS 1LE
I went with summit racing for the 0w-40esp.
My 2 local dealers wanted $15.50 and $23 PER QUART!
I told them they need to lookup case prices and both replied this is the price GM sets.
I told them summit racing (it’s 5 miles from here) sells them for under $10 per quart and they wouldn’t do anything at all. Not sure if my dealers just suck or if they are all like that
Gasoline_Farts is offline   Reply With Quote
Old 03-17-2019, 09:58 AM   #6
JD_
JD_'s Avatar
Drives: 2018 2SS 1LE in Nightfall Gray
They are all like that. I got mine from Napa Auto parts for about $6 per quart when they had it on sale. Might be worth giving them a look.
JD_ is offline   Reply With Quote
Old 03-17-2019, 10:31 AM   #7
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Motul X-clean is $9 a quart on Amazon. Napa is great when Valvoline is on sale. I bought 22 quarts last time.
The new M1 dex2 will be at Walmart eventually, and hopefully for 25$ for 5quarts
thescreensavers is offline   Reply With Quote
Old 03-17-2019, 11:57 AM   #8
artey34
artey34's Avatar
Isn't the 0W-40 ESP the new recommended for street use and track use? So I wouldn't need to swap oil just to swap between the 2?
Old 03-17-2019, 12:06 PM   #9
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
Exactly.
It is also a low saps oil that helps with valve deposits on our direct injected motors.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
Airfuel is offline   Reply With Quote
Old 03-17-2019, 01:43 PM   #10
TrackClub
TrackClub's Avatar
No. No need to swap between track and dd with any of the recommended Dexos 2 oils per the manual.
All the new Mobil 1 oil does is enables GM dealers to sell Dexos 2 oil for our cars which is good for BOTH track and DD. Until now they had no such oil to offer as they were limited to semi synthetic 5w30.
I use Valvoline 5w40 Dexos 2. Better summer weight imo for warm vs cold starts. Also recommended in the car's manual amongst others. Yes: it is good for both track and DD duty. Per the manual.
Old 03-17-2019, 02:14 PM   #11
Soleil
Soleil's Avatar
Although it is the same oil I would always change oil before and after the track day. On the track the oil will be heavily used.
Soleil
Old 03-17-2019, 02:27 PM   #12
Whocares05050
Drives: 2018 Camaro SS 1LE
mine wants $16.78 per L (they are not quart bottles) each here in S. FLA
Whocares05050 is offline   Reply With Quote
Old 03-17-2019, 02:55 PM   #13
Airfuel
Airfuel's Avatar
Drives: '19 2SS M6.
The M1 0W40 esp from Amazon is quarts. ($49.99 per 6pack, now 54.99)
Strange that dealers sell liter bottles.
Old 03-17-2019, 03:25 PM   #14
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
I've also been running the Valvoline 5W-40 MST for both track and street with 0 issues for the last two summers. Meijer carries the 5 qt. jugs for $20-$25 in all the stores I've been to in the Metro Detroit area, so I'd assume the carry it in all of their stores. Only place I've been able to find it that cheap, too.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
