05-14-2018, 09:30 AM | #1 |
Drives: 2011 Camaro SS Join Date: Nov 2014
help me find a H pipe?
So my car came to me with bbk longtube headers and a pype bomb axle back which I love but it is true dual exhaust. I have been reading that this is terrible for l99/ls3 cars. I did find the jegs/summit xpipe that is affordable but haven't been able to find a H pipe. I have a tick polluter cam and I am worried the choppiness will be affected with a xpipe so I was really looking for a H in the same price range. Thanks. car put down 464/441 on dynojet maybe the mid pipe would up it a few ponies and bring my torque up?
05-14-2018, 12:32 PM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Go with the x pipe... you'll thank me later
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
05-14-2018, 12:40 PM | #3 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
05-14-2018, 12:41 PM | #4 |
05-14-2018, 01:43 PM | #5 |
05-14-2018, 03:24 PM | #6 | |
05-14-2018, 03:38 PM | #7 | |
Drives: 2014 SIM 2SS Join Date: Sep 2015
05-14-2018, 04:11 PM | #8 | |
05-14-2018, 06:01 PM | #9 |
I've had all 3 setups. The tru dual is going to let you "hear the cam" the most. Once you merge the 2 pipes it is going to muffle the rat tat tat... the x pipe is raspy and the most aggressive sounding to me. It sounds angry to me...
05-14-2018, 06:13 PM | #10 | |
Drives: 5th gen Join Date: Oct 2016
It makes very little difference
05-14-2018, 06:20 PM | #11 |
Power wise... yes, very little difference. However, I think there is a decent/ noticeable difference with the x pipe.... not so much with the h pipe.
05-14-2018, 06:24 PM | #12 |
Probably true. They had a plausible explanation for this in the video, as exhaust velocity increases amount of crossover decreases in the H configuration, where the x preserves crossflow at high velocity
05-14-2018, 06:39 PM | #13 |
So nobody knows of a H pipe design for sub $100 like the xpipe that summit and jegs offer?
05-14-2018, 06:42 PM | #14 |
I still have my factory piece if your interested...
