05-03-2018, 07:28 PM | #1 |
Drives: 2010 camaro Join Date: Dec 2017
Any good coilovers out there for an ss?
I've been wanting to get coilovers for my 2ss but want them to perform well on a track, don't want them just for looks. Anyone who has tracked with coilovers please comment on the tread.
05-04-2018, 12:00 PM | #2 |
kw and bc or megan racing are about only options if you want a good track coilovers dsc i believe is about only option the rest are pretty much just for looks
05-04-2018, 06:16 PM | #3 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
MCS is a track coilover setup. It not the cookie cutter appearance coilover most will go for.
I helieve ots around 6k, bit i know the rear is adhusted through geound controls weight jacker syatem and i have seen a local who has em use the ground control camber plates up front. There was a post of em from a while back. https://www.camaro6.com/forums/showthread.php?t=475298 They are a bit more than the gm dssv setup, but do offer more adjustability. Theres two more companies that have offerings as well, i ve called and found... but their upwards of 5800 up to 7k in price. Most will just slap on kw's at best and run em.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
05-04-2018, 08:40 PM | #4 |
sounds like kw would be the best choice for me to go after. Thanks for the responses.
