04-20-2018, 12:28 PM | #1 |
Drives: 2012 Camaro SS Join Date: Oct 2017
Paint Correction
I have a black car, and there are some swirls. It looks like someone used a power polisher with a little too much force. It looks great most of the time but in full sun the swirls are quite visible. So I am thinking of getting a correction done. First place I visited asked $800. Is this what I should expect?
04-20-2018, 01:14 PM | #2 |
go on the autogeek website,study their videos and you should be able to take care of the paint correction yourself for less than 300 bucks and have an orbital buffer/polisher and plenty of supplies left because you will find keeping your car looking good will become your new hobby.i practiced on my wifes older nissan first and even got that faded old POS to look pretty good before i tried it on the camaro.expect to spend most of a day on the first try.
04-20-2018, 01:20 PM | #3 |
Drives: 2013 camaro Join Date: Mar 2013
That doesn’t sound bad from what I have seen and heard abroad. Have you ever thought about correcting yourself. Time consuming yes...but you will save yourself more than half of that 800.
I wasn’t to big on doing it myself when I first got my Chevy, but seeing these prices out here I just took a dive, one of best decisions for my car. My car is a 13 and I still get great compliments on the paint because of the work I do? I checked out the junk man, his videos are great!!! How I leaned. Part 1 for machine polishing for novices. https://m.youtube.com/watch?v=KP-eAddv2sk Part 2 https://m.youtube.com/watch?v=h_0nr6XPEHM -jumps into the tools and products Part 3 Car prep and work https://m.youtube.com/watch?v=PyJYtYhz9RQ Part 4 Actual polishing procedures and techniques https://m.youtube.com/watch?v=P0rbZOeNN4o Great deal of knowledge. Even if you don’t end up doing it. Just a good JFYI type of references to have Good luck |
04-20-2018, 03:52 PM | #4 |
Great vids. I watched them all, and I get the plan. I might just give it a try.
04-20-2018, 04:58 PM | #5 | |
Drives: 2018 ZLE Join Date: Feb 2018
Lucky that auto geek is 10 minutes from my house. I bought there kit and have done about 40% of my car and really works great. The videos are great. |
04-20-2018, 05:02 PM | #6 |
Try some compound. Don’t use too much force with it but it’ll get the swirls out no problem.
Life is short, drive it like you stole it! |
04-20-2018, 05:58 PM | #7 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Polishing compound--not rubbing compound. Rubbing compound is too abrasive for modern clear coats. Used to work fin on old enamel or lacquer finishes, but will go through the modern paint quickly, due to thinner paint.
04-20-2018, 07:07 PM | #8 |
Correct. You can use rubbing if your light enough and know what you’re doing. But I agree polishing compound is way to go
04-20-2018, 10:07 PM | #9 | |
Drives: 2017 50th Anniversary 2SS Camaro Join Date: Jan 2016
Sent from my SM-G965U using Tapatalk |
