03-02-2021, 11:25 AM | #1 |
Drives: 2019 2SS 1LE Join Date: Feb 2021
What is the recommended wheel cleaner?
Since the search isn't working right now, what is the recommended wheel cleaner for the 1LE wheels? Need to clean the car up...had a long drive from SD to home.
03-02-2021, 11:49 AM | #2 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
I prefer Sonax Full Effect @ full strength if you haven't cleaned them in a while and want to get embedded brake dust out.
If regular maintenance, I like P&S brake buster in a foaming sprayer diluted 10:1 with distilled or filtered water (don't want to clog the foamer). |
03-02-2021, 06:23 PM | #3 |
Drives: like an old lady Join Date: Jun 2012
a very mild, ph balanced soap.
ceramic coat the wheels and calipers. they will look new, every time for years to come, with minimal effort and no special attention.
03-02-2021, 08:35 PM | #4 |
Yeah, I just ceramic coated my new wheels on my Solstice and they're so easy to take car of...I will do that on this one now.
03-03-2021, 07:21 AM | #5 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I haven't found one that I'd call superior or the best, I like the Meguiars wheel brightener that you dilute it down with water. But then I'm always brushing and getting in there with different brushes and agitating the cleaner so as far as a "hose off" cleaner, never seen one yet that would handle 1LE with Brembo pads level dust. This is an acidic type cleaner that I dilute about 50/50 and treat it as a single use as it kills a spray bottle pump when left in the bottle. it dilutes at up to 4:1 so you can vary the strength.
03-03-2021, 09:00 AM | #6 | |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
I also use this and it works great. https://www.amazon.com/Detailers-Pre...4783603&sr=8-2 |
03-03-2021, 11:04 AM | #7 |
There are a gazillion good cleaners out there. Schuck's or Pep Boys or NAPA can point one out to you
'20 ZL1 1LE A10,
03-03-2021, 11:12 AM | #8 |
cool guy wheel cleaner is what i use after my track days
03-03-2021, 12:16 PM | #9 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Chemical Guys Diablo wheel cleaner
03-03-2021, 02:29 PM | #10 |
Drives: 2021 LT1 Join Date: Aug 2020
03-05-2021, 02:29 PM | #11 |
Thanks for the input guys. I wasn't sure what to use because my Scat's weren't clear coated and I had to be very careful with them. They were Matte without any protective coating (which explains why the inside of the wheel rusted it left wet). Wasn't sure what to use on the Camaros until I really cleaned one up and realized that it does have a protective coating over the paint!
