Old 05-22-2016, 10:19 AM   #1
dcamaroguy
dcamaroguy
dcamaroguy's Avatar
Drives: IOM 2010 Camaro 1SS/RS LS3
Low MPG after storage
I was wondering if anyone had any ideas on my issue. I stored my car in December for the winter. I avergaed around 15-16 mpg. Pulled it out of storage in March, changed the oil (Mobil 1) and cleaned the filter and TB. Since getting it out I notice I am only getting 13-13.5 mpg. Drive is the same every day (short commute) and my driving habits did not change. Any thoughts?
2010 IOM 1SS/RS-Dominator 2 cam kit, G5CR CAI, Texas Speed headers, Borla cat-back, 20" ZL1 replica wheels,Hurst shifter,Elite catch can,custom tuning by Rapid Motorsports
dcamaroguy is offline   Reply With Quote
Old 05-22-2016, 10:21 AM   #2
Trifecta23
Trifecta23's Avatar
Drives: 2013 Dusk 2ss/RS conv.
Did you do a fuse pull?
2013 Dusk Camaro/Convertible/2SS RS/6 Speed Auto/One of Sixty Nine
jdm
Trifecta23 is offline   Reply With Quote
Old 05-22-2016, 10:46 AM   #3
dcamaroguy
dcamaroguy
dcamaroguy's Avatar
No fuse pull. Didn't think I had to because it has a custom tune and the battery was disconnected while in storage
Old 05-22-2016, 01:54 PM   #4
Flotek
Flotek's Avatar
Drives: 2015 RS camaro
Make sure mice didn't find their way into anything
Flotek is offline   Reply With Quote
Old 05-22-2016, 03:40 PM   #5
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
Rest the MPG-
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 05-22-2016, 10:27 PM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
then you dont need to do a fuse pull as both tables are the the same tune. did you put fuel stabilizer in it and it has the old gas in it? that can do it. How bad was the tb. if it was bad the car has to relearn. you should clean the MAF with MAF cleaner too. clean your MAF put a couple of tanks through it then check it again.
to clean the MAF get a can of MAF cleaner and follow the directions on the can. do not wipe it or touch it with anything other than the cleaner. MAF has to be warm when you do so take it for a short drive. get your tools ready to pull it and open the hood shut the car off then pull it and spray it.
Old 05-23-2016, 08:27 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
If you disconnected the battery, your avg mpg reset. When you pulled the car out, changed the oil, and all that goes with pulling a car out of storage, my guess is that you probably spent more time at idle than you did when you put it away. Clear the MPG again, and drive as normal, it will get back to where you were eventually.
MrChrisLS3 is offline   Reply With Quote
Old 05-23-2016, 07:33 PM   #8
dcamaroguy
dcamaroguy
dcamaroguy's Avatar
I have run about 3 tanks of fresh gas through the car since taking it out and I reset the fuel mileage at each fill up. The TB was pretty dirty so I will give the MAF a look this weekend. Thanks for the tip.
Old 05-23-2016, 09:03 PM   #9
Car.freaks
Car.freaks's Avatar
Drives: 2014 Chevy Camaro SS
Smile fuel injector cleaner
walmart has Techron fuel injector cheaper than auto zone or advanced auto. Get some and use it. After that tank use Lucas fuel injector cleaner and you should be good to go. It doesn't take much to clog up these new injectors.
Car.freaks is offline   Reply With Quote
Old 05-23-2016, 10:36 PM   #10
havelegs
havelegs's Avatar
Drives: '23 LT1 A10
I only get about 250 miles out of a full tank :(
havelegs is offline   Reply With Quote
Old 05-24-2016, 06:15 AM   #11
paul84043
paul84043's Avatar
Drives: 2015 Camaro 2SS RS 1LE
If your girlfriend put you in storage and hung out with a different guy for 4 months, you'd probably be kind of upset too...
paul84043 is offline   Reply With Quote
