05-16-2023, 12:07 PM | #29 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Severity went from severely limiting brake force for long enough to cause major issues to a momentary event that only extends braking by a relatively small amount, you might miss your apex by a bit but won't be going off course entirely. I've done quite a few autox races and a couple track days since switching to the '19 EBCM.
05-16-2023, 01:19 PM | #30 | |
Drives: 2021 1SS 1LE Join Date: Nov 2020
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
05-16-2023, 01:51 PM | #31 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
A couple questions for everyone... What if any role do you think that the slicks play in the recently reduced amount of icemode from your last two track days? Or did the data show you were just braking differentlly? My guess is that those slicks are more evenly and appropriately matched with the grip level of the brake pads you have on the car now. Did you notice any correlation between ice mode and how fast you transitioned from gas to brakes? Lastly, you don’t have any PDR video of your ice mode incidents do you?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
05-16-2023, 01:52 PM | #32 | |
Having said that, it sounds like with Ken's data, if done right, applying full braking by .4 seconds should not really should impact lap time significantly, I think the hard part would be to not overdo the slowing of the brake application when changing braking style
05-16-2023, 02:03 PM | #33 | |
One thing I should say is that I forgot that the fact that my main wiring harness that runs the entire length of the car was literally melting from being too close to the long tube headers and was causing a variety of other problems like; my steering locking momentarily mid corner, my gears shifting on their own despite being in manual mode, random horn honking on corners and finally traction control and stability control failed later as well... so some of the "ice mode" I was experiencing could have been from this as well (It cost $12,000 to replace the wiring harness after failed attempt to splice all of the wires back together again). Fingers crossed that this was making ice mode worse than it should’ve been because going off the track three times in three half track days really scared me considering dirt banks and walls were next…
05-18-2023, 12:49 PM | #34 |
I'm also going to try the Hawk DTC60's front and rear and see if that helps make a different compared to the Hawk DTC70's
05-18-2023, 01:37 PM | #35 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I only have a few sessions on the 3Rs at this track but definitely felt I was having to hold back under braking more at this track than the several other (smoother) tracks where I have also driven on the 3Rs. Here's my PDR video of Harris Hill before/after EBCM swap on stock Supercar 3 tires. I was purposely trying to stab the brakes hard right after full throttle for many laps here and at MSR Houston Clockwise but never got ice mode with the updated EBCM while I got it multiple times at both tracks by accident with the stock EBCM including a trip into the grass in the same spot at MSRH at 2 different events months apart. https://youtube.com/watch?v=TLDWA4nfqX0 |
05-18-2023, 04:33 PM | #36 | |
I’ll watch that vid soon
05-18-2023, 08:05 PM | #37 | |
Drives: 2021 2SS 1LE Join Date: Aug 2020
That said, while on track I have trouble feeling ABS activate through the brake pedal on my 1LE. It doesn't seem anything like the usual vibration feel of everyday cars. Can you describe what YOU feel through the pedal when your ABS activates? |
05-19-2023, 12:37 AM | #38 | |
I did an autocross school shortly after I got the car and remember feeling ABS a bit through the pedal when the exercise was to purposely engage it by stomping the brake pedal but that was years ago. How do you check for ABS engagement with the PDR .mp4 file on a computer? |
05-19-2023, 03:07 PM | #39 | |
Once you learn how to use PI toolbox to access and plot your laps as graphs, there is a sensor channel you add to the plot for ABS. For each lap plotted, you can look at any point in time during a lap to see if ABS is off (Y axis value =0) or activated (Y axis value =1). Looking at brake zones (speed dramatically decreasing, brake pedal pressure increased), you'll be able to tell if ABS activated and how much pedal % it took to trip it. Also will show you whether you had any ABS during trail braking toward to the apex (that's usually where I'll see an infrequent ABS blip that I could not sense was happing in real time - I'm not activating ABS during straight line braking). You can do the same thing looking for stabilitrack activation (it has a sensor channel for that), in the event you are running PTM Sport 1. |
05-21-2023, 09:56 PM | #40 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
So, no issues this weekend at VIR with hawk DTC 60s on the front and rear. Using 315/30/18 square all weekend, and I pushed the car as hard as I could, I almost felt bad. Went through the esses flat, now there is no going back to lifting anymore.
05-22-2023, 08:54 AM | #41 | |
Remind me, you were on the 70s on the front before?
05-22-2023, 09:08 AM | #42 |
