10-15-2021, 10:55 AM | #1 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
My build is almost complete!!
It's been quite some time since I dropped off my ZL1 to get modded and there were a few snags and delays along the way. But it is just about finished. It was on the dyno a few days ago and I got some numbers. But I opted to go for a little bit more. Here is where I am at.
Build includes: Whipple 2.9 (originally I planned for the Maggie 2650 but we had issues getting one). TSP stage 2 cam (DOD delete). PRC ported heads. TSP 2 inch LTs. Full 3 inch exhaust (MBRP Race catback). Big Gulp intake. NW 103mm TB. DSX Aux pump. Flex Fuel setup. 93 Octane tune, 100 Octane tune, Flex Fuel tune. Other ancillary items (plugs, etc...) So aiming for the Heavens I was hoping for 850-ish to the wheels on 93 octane and closer to 900 on 100 octane. I dream big. I'll be happy tho with 800-ish on 93 and 850s on 100. On the dyno so far we hit 730s to the wheels but the pull was in 6th and that was with the lower than expected boost (I believe it was just under 15 psi). I wanted to squeeze a bit more boost out so we ordered another pulley and belt and will see what that gets us. I'm aware that 7th is the 1:1 ratio and ideal for pulls but we have to go with 6th due to restrictions with the dyno. So I'm guessing that is costing me some power...maybe around 30. The new pulley should get me to right about 16 which should squeeze out a bit more. I'm guessing that if the pull is in 7th then I'd be seeing high 700s on 93. As it is I'm guessing mid 700s with the extra pulley and the 6th gear pull. The 100 octane pull should be high 700s but I am hoping to break the 800 mark with 100 octane in 6th. I am also having an E85 setup and tune added in with a gauge. I'm thinking that will be good for high 700s on E30-40...?? Guesses?? Hopefully it will all be buttoned up today or tomorrow. If not then early next week. I'd like to see some guesses on my final numbers. I will update as soon as I get them. Also, in NJ we have 93 octane everywhere. However I am in Nebraska for a work assignment and will likely have the car out here for a few months to a year. In Omaha the max is 91 octane. Any suggestions on octane boosters that are safe and reliable? I might just get a 91 octane tune added in for safety. Ideas?? |
10-15-2021, 01:35 PM | #2 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
only issue with the parts i see unless things changed since i did my build last year is the TSP cams having 32% fuel lobe instead of the 38% like BTR. Your build is very similar to mine except i didn't do the ported heads and of course mine is 2650. I am seeing e30 as doable. My Fueling on both sides is holding well. My Inj pulse width is in the 5.9-6.2 range on e32. Still trying to dial in the Lambda...i seem to be .84 to .86 range. Only regret was not doing the 30 over injectors, but they are so damn expensive.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
10-15-2021, 01:37 PM | #3 |
Forgot to mention you will want to do a lower pulley too as i didn't see it on the list of parts if u really want those kind of numbers without adding Meth to the mix. I chose not to use Meth for my build. I will do injectors before doing meth.
10-15-2021, 01:39 PM | #4 | |
'20 ZL1 1LE A10,
10-15-2021, 01:58 PM | #5 |
me or Blaq? I didn't do high side. I did do the Lingenfelter high flow check valve, but that is low side as well. Another item to add to the list Blaq! I wish while the blower was off i did the 30% injectors. Doubt i would have done the Big Bore pump..Very expensive for only up to 10% flow increase on LT4s. I would think the injectors is more bang for the buck.
10-15-2021, 02:56 PM | #6 | ||
Again my numbers are in 6th gear which is about 30 HP lower than 7th. |
10-15-2021, 02:58 PM | #7 | |
10-15-2021, 04:29 PM | #8 |
Pretty much same here..I am in the 15/16 boost range. I think your goal is doable with ur parts list. And as I have learned depending on what afr/lambda the tuner uses. At .8 Lambda I was 801rwhp on 100 octane, but after retune and at .88 Lambda 805 on 93. On e47 was 848rwhp but manifold Temps were high in 165 range. My end game is e30 without doing high side.
10-15-2021, 07:21 PM | #9 | |
10-15-2021, 08:36 PM | #10 |
Depends on who you talk to since 99% on this forum say too lean, but can't say there is any data to prove them right. I have been readjusting mine to be in the .84 to .87 range while at e30. My fuel pressure on both low and high side have been good and steady. Inj pulse width based on a log from tonight was 5.7 to 6.1 range. On 93 octane it was 5.0 to 5.2.. My reason to run e30 is the cooling benefit plus being able to get same or better gain and can stop having to add boostane.
10-15-2021, 08:42 PM | #11 |
This guy did mine..if you forward to 9min mark he mentioned what afr he likes for LT4s. This is not my car.
https://youtu.be/rqQ5cNQVeX8
10-16-2021, 01:06 AM | #12 | |
Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
10-16-2021, 01:10 AM | #13 | |
10-16-2021, 02:40 PM | #14 | |
I'll look into the Boostane and Torco. But will it be enough to bring 91 octane up to 93? I figure a full tank out here will probably last me about 2 months. I figure I DD my truck and I filled up around Sept 24th and didn't have to refill it again until a couple days ago. So my ZL1 which won't be my DD will probably last much longer. |
