04-21-2021, 07:57 AM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Weird OTA update this morning
Go to work and car said update ready, will take 11 minutes etc...
Put the car in 1. Put on ebrake. Turned off car. Hit update. When I got out the stereo was still playing and the screan went back to the normal icons. The car was definetely off. So I got back in started up the car pulled forwards then backed back in to my spot. Turned off the car and all appeared normal but the update did not run. So i went into setting and it said up to date. Weird
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
04-21-2021, 01:49 PM | #2 |
Drives: 2020 Camaro SS 1LE Join Date: Aug 2020
Completely normal when an update is needed. Radio will shut off in a couple minutes on its own if update is not completed. Once update completes radio will go back to normal operation and shut off when you open the door. Has happened to me 3 time in 9 months. Usually takes my car 3/4 times before it will finish the update.
04-21-2021, 02:11 PM | #3 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
04-21-2021, 02:37 PM | #4 | |
Drives: '21 Camao SS, BMW 435i, M Roadster Join Date: Oct 2020
I never activated OnStar either and I have seen the update message a time or two.
2021 Camaro SS Riverside Blue Metallic
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Asst Pkg, Prem Pkg, Tech Pkg, 8 Spd Sport AT, Heated Front Seats, ACC, BMW M Perf Tune w/MPE, BMW LSD, BBS CH. 2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Steel Gray Metailic HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. |
04-21-2021, 03:23 PM | #5 | |
When I got home I tried again an it worked as usual, the music turned off and the status screen stayed up.
04-21-2021, 04:41 PM | #6 |
Thank you for responding, good to know for sure. I have gotten no update messages at all, car is 5 months old and have driven 4500 miles. I quess this may be side benefit of a no option LT1 other than the 10 speed auto.
04-21-2021, 08:55 PM | #7 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
onstar activation only matters for you personally using the onstar service. It's always connected to the cell network whether you pay for it or not and GM can push updates and/or get data from your car whenever it wants. Whether you have an active subscription or not.
Only way to stop that is taking the cell radio out of the onstar bcm. |
04-22-2021, 08:08 AM | #8 | |
Hot Camaro
To my knowledge, there has been only one update that would apply to my car that was released this year and it was installed recently (by me). |
04-22-2021, 11:04 AM | #9 | |
04-22-2021, 11:13 AM | #10 |
Drives: 1994 z-28, 2017 2ss 6spd Join Date: Mar 2018
I have a 2017 2 ss car with the bose upgrade system and to my knowledge never have received an update.
Does this sound correct? Thanks. |
04-22-2021, 11:16 AM | #11 |
Hot Camaro
04-22-2021, 11:20 AM | #12 | |
Someone will correct me but 19 or 20 with the radio3 update.
04-22-2021, 08:04 PM | #13 | |
I had to reconnect my car to the home wifi, though nothing has changed with that. It started "updating," and I ended up with a few more apps I will never use. Nothing in the system update area. I'll make sure it stays connected to wifi in case anything gets pushed. But I am out of town for 2 weeks. |
04-23-2021, 12:40 AM | #14 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
I believe it was the 2019s, or whenever they released the upgraded Infotainment system with the higher rez screen, that the ability to update the software in the radio was available.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
