04-16-2021, 09:48 PM | #1 |
Drives: 2022 C8 Z51 Join Date: Feb 2018
LT1 - can u get 600whp out of one w/o forced induction?
Want to build a fun car for late night fun and time attack track days. Specifically, HP potential in a 2017 or newer 1LE
* CAI * Cam * headers * exhaust * e85 * manifold * ported throttle body Just curious what a reasonable HP ceiling is before getting exotic and wishing you got a ZL1 1LE instead. I see a lot of 500-515whp projects. Can you get 600whp? No nitrous, Turbo, or super charger. No alky either. And does anyone have their favorite cammed LT1? I want a chop chop that draws attention and crowds in parking lots. Thanks. First time ever considering American. Want to lay down some American Attitude Loud & Proud.
Owner: Shifts & Giggles for Private Track Days in OK/TX/KS. COTA, MSR Cresson, Eagles Canyon, Hallett, Heartland Park Topeka.
2006 EVO IX RS Track Prepped 2020 Porsche Cayman 718 GT4 2022 Corvette C8 Z51 with mods 2024 = Always come back to ZLE. Actively Looking. |
04-16-2021, 10:08 PM | #2 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
Yes you can make over 600whp NA. Do some research you’ll find a few builds on here.
04-16-2021, 10:21 PM | #3 |
These threads/links are some good reading.
https://www.camaro6.com/forums/showthread.php?t=575143 https://www.torquenews.com/106/meet-...ated-6g-camaro https://www.camaro6.com/forums/showthread.php?t=580311 https://www.camaro6.com/forums/showthread.php?t=548004 Blackbeast’s 2016 sure sounded good and this was with GM’s hot cam.
04-16-2021, 10:35 PM | #4 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Mine is a little more exotic than your list but it can be done NA. This was a 5th gear pull on 93. https://www.google.com/url?sa=t&sour...weoCWZHTuIgg9K
04-16-2021, 10:45 PM | #5 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
04-16-2021, 11:14 PM | #6 | |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
04-16-2021, 11:40 PM | #7 |
Op you're going to have to add ported heads on your list if you want to make it to 600. If you leave those out you're losing 25 to 30hp depending on the head.
04-16-2021, 11:41 PM | #8 |
04-17-2021, 01:17 AM | #9 |
Awesome feedback guys! Thank you so much for the links, your examples, and reminder about ported heads. So frustrated at used ZLE prices, I’m excited to build up a 1LE & say F the used car market! Coming from a high strung 700hp rice box, I think a built 1LE will be a a comfortable street/track toy. Got a good tuner here in the 405.
04-17-2021, 07:10 AM | #10 |
Regarding brand name aftermarket companies, is Pray For Performance at the top? I see this company mentioned a lot. If one was trying to pick the proven best quality of parts, what would that look like....ported high ram intake manifold, cam, etc...
04-17-2021, 08:53 AM | #11 |
Yea he's pretty good but getting parts and work done from him is a pain because he's basically a one man show. Gpi is another good option that specializes in Na cars and has great customer service. If you have a tuner picked out already I'd just purchase everything from GPi. On your manifold choice you can get to 600 without a high ram if you're not wanting to cut a hole in the hood. Call Gpi and tell them your goal and they will set you up.
04-17-2021, 08:59 AM | #12 |
On heads choices there are a few more than when I did my set up. Ported heads work fine but you can run the chance of getting casting and they end up leaking and hydro locking your motor. Mast Motosports has a beautiful set of heads and if they were available when I did mine I would've bought theirs instead of porting mine. Cid,Texas speed, and Katech also have aftermarket sets now that also look good.
04-17-2021, 09:17 AM | #13 |
Drives: 17 SS 1LE Join Date: Dec 2015
I feel like 600 NA whp will require a big cam that sacrifices driveability. Keep in mind you will either have to run a phase limiter or disable variable valve timing completely with any cam swap.
LT2 manifold, ZR1 TB, a sub-.600 lift cam, E85, ported heads, and LT headers should result in a tractable low-to-mid 500s engine that doesn’t eat valve springs (with a good tune). The SS 1LE is not a numbers car; you are better off starting with FI if you prioritize figures over driving experience. Last edited by WhyUMad1LE; 04-17-2021 at 09:30 AM. |
04-17-2021, 09:40 AM | #14 |
600whp in a SBE LT1 is doable even with a moderate sized cam(22X/23X .6XX .6XX 113). It will require more compression, ported MSD, good set of heads, headers, rotofab, and E85.
Pray's stock castings completely reworked from the valve seats on up run about 4500.00. Or get a set of aftermarket CID or Mast castings. Either way the power is made in the heads and intake selection...the cam determines the rpm range where you want to make the power. Ideally you select the cam based on the heads/intake. Prays cam grinds seem to work really well. For example His Stage 3 makes about 50+whp more then TSP's VVT3 and has been reported to offer better driveability. I can not comment about longevity however. I haven't seen any reports of mileage being logged on these builds. That being said if I was going to do a H/C build for a street car with longevity and mileage being a factor, I would probably look at some Cam Motion cam packages. I really think they offer some of the best lobes and I believe keeping the lift around .600 ensures better valve train reliability...especially with stock rockers.
2016 NFG 1SS A8
