03-17-2021, 06:36 PM | #1 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
Front wheel on rear?
I have a spare set of OEM 20" front wheels for my 2018 2SS (not a 1LE) and am wondering if they will fit on the rear
Thinking of putting a set of cheap tires on them and making a "fun" set of wheels for stress relieving smoky burnouts Obviously the size and bolt pattern are not an issue, just not sure on the back spacing
03-18-2021, 07:37 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
They should fit without an issue. The fronts are 1 inch (~25mm) narrower than the rear and have 14mm less offset. That means they'll only stick out 1.5mm more on the outside than the stock rears and the inside edge will have a little over an inch more clearance. If I'm not mistaken, I think this is what's done on the LT1 trim Camaros.
2017 SS 1LE.
