10-05-2019, 04:22 PM | #1 |
Drives: 2017 procharged camaro 2ss Join Date: May 2018
305/45/17 Mickey's
Has anyone experimented with the 26in drag radials vs there 28in drag radials and had any improvements with the shorter tire? I don't think the shorter tire will help?
10-05-2019, 05:44 PM | #2 |
I don't think you'll see improvements with a 26 on a FI car. Lots of guys running them on NA cars but can't see it working on your car. I want to run the tallest tire I can on a Supercharged car.
10-05-2019, 09:22 PM | #3 |
Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
26 is good for a couple mph and 2 tenths but if you cant plant the power then the differences overcome one another by being able to plant the power on a 28
10-06-2019, 11:52 AM | #4 |
Thanks for y'alls help, I'm wanting to get in the 9s and not sure if the shorter tire would help, I don't think it would at this level, and I'm not sure if I'll get the .31 I need with better da and temps, but I'm gonna find out with cooler weather in the way
10-06-2019, 05:19 PM | #5 |
Not necessarily for a FI car or even for a NA car, each car reacts differently depending on the tune, suspension and power. Stay with a 28".
10-08-2019, 11:30 AM | #6 |
Drives: 2016 camaro ss convertible Join Date: Dec 2016
I just went from a 26 to a 28 and I feel the car improved. I think bolt on cars are the ones that see the improvement when lowering the tire diameter.
10-08-2019, 11:53 AM | #7 |
I'm on a 26" and cross the line at 127 @ 5700 rpms or so. that 4-5 shift really sucks. I would think on a 28 it would even be worse. I thought the shorter tire is like a lower gear ratio, therefore keeping me in a higher rpm and in boost quicker. But, I've been wrong before.
That being said, I have both a 26" & 28" 555Rs. I DD the 28". Next time to the track I'm trying both. My current race tune is for 26". I have a 28" tune that I'll have to play with. But added a couple mph to each shift point to start off with. I actually asked this question 2 years ago:https://www.camaro6.com/forums/showthread.php?t=507829
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. Last edited by grampa_ss; 10-08-2019 at 12:46 PM. |
10-08-2019, 05:42 PM | #8 |
You would be better off keeping the 28 and putting a good converter in the Car...especially on a Centri setup.
2016 NFG 1SS A8
10-09-2019, 06:20 AM | #9 |
Thanks for everyone's help, the car has a d1sc 4.0 pulley msd im kooks lt meth no cats circle d 3700 racestar with mt 305/45/17 runs 10.31@133.7 dss axles and driveshaft sbe and wanting a 9.999 not sure if the 26in would get me there?
10-09-2019, 07:49 AM | #10 |
I run that same 305 and my best 60 ft is a 1.35 and best mph is 147. Not gonna happen on a 26 inch tall tire. I'd like to run a 29" but inner fender clearance is the issue for me and I plan on doing the 15" conversion this winter so I may be able to find a 29 and squeeze it in there. Might have to take out the liners but that's no big deal. I just don't think the 26" with an FI car is your friend. You might look at the top of the fast list to the procharged guys, no 26s on those cars, 28s or taller.
10-09-2019, 08:12 AM | #11 |
Drives: 2016 Camaro SS Join Date: Sep 2018
Typically on a boosted car you want to run a taller tire, I doubt you'd help your situation honestly. Can you not just pulley it down a tad? That should get you over the hump.
