06-05-2021, 01:29 PM | #1 |
|Engineer|
Drives: 2016 Camaro SS Join Date: Aug 2016
305/35/20 tires on MRR 1LE rims.
I have the MRR 1LE replica rims and current run with 305/30 275/30 tires. Can I move to 305/35 and 275/35 tires without any rubbing issues?
2016 Camaro SS A8 | Magnuson Heartbeat | Might Mouse Wild Catch Can | DSX Flex Fuel | Eibach Pro Kit | Flowmaster Outlaw Black Series | MRR 017 Wheels
06-05-2021, 01:35 PM | #2 |
2020 Shadow Gray 2SS
From what I understand, you'll be ok with 305/35's as long as you relocate the wiring harness in the left rear wheel well (a fairly easy job)...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
06-05-2021, 05:40 PM | #3 | |
https://www.camaro6.com/forums/showp...57&postcount=6
06-05-2021, 08:20 PM | #4 |
Drives: 2016 Garnet Red 2SS A8 Join Date: Jul 2017
I am running 275/35 and 305/35 without much trouble but I did relocate the harness. Some rubbing up front when and full turn and on and incline but very minimal
2016 Camaro 2SS - Auto - MRR 017 - Garnet Red
P1X w/ Stage II IC, LT4 Fuel System, JMS Voltage Booster, MMS Catch Can, JRE Off Road Pipes, JRE Tune |
06-06-2021, 07:05 AM | #5 |
Drives: 2019 2SS Camaro Join Date: Apr 2021
Hey can you take the rear run flats (275x35x20)and mount them on MMR 017 fronts 20x10s? Not trying to high jack the thread but I have search the forum and can't seem to find the answer. Got 305x 35x20 MTs for the rear 20x11s.
06-06-2021, 08:00 AM | #6 |
Yes. Without spacers they may rub a tiny bit on the driver side at full lock.
06-06-2021, 11:15 AM | #7 |
06-11-2021, 11:33 AM | #8 |
Drives: 2016 2SS blue velvet w/blk stripes Join Date: Sep 2017
i assume your wheels are 23mm offset in the front? Im about to do the same. Does the rearend sit noticeably higher with this set up? 305/35s are an inch taller then the 275/35s in front.
06-11-2021, 07:13 PM | #9 | |
The rubbing is very minimal and would probably go away if I lowered tire pressure a bit, want me to post a photo? To all those who want wide and tall 35 aspect ratio tires in the rear, it's a Russian roulette, some people have Stabilitrak and ABS errors due to the large difference compared to stock. I run 315/30/20 tires on 11" rear wheels, which retains the stock non-1LE front/rear ratio almost perfectly. EDIT: here's what the spot with the minimal rubbing against the driver side front wheel well liner looks like. It's not getting worse now that I lowered tire pressures.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 06-12-2021 at 02:51 PM. |
06-11-2021, 11:19 PM | #10 | |
I'd really like to go to 1LE wheel setup when it comes time for tires, but have heard mixed reviews on the MRR wheels... I don't plan to track, but definitely want to safely do some very "spirited" driving... I LOVE the look of the 1LE wheels (and the size), just want something durable, reliable and safe...
06-12-2021, 12:11 AM | #11 | |
The paint job on my gloss black set isn't perfectly uniform across the wheels, I could probably polish up the ones that aren't at the exact same gloss level, but my plan is to powdercoat them eventually. In summary, I think they're fine, especially considering they cost half as much as the OEM 1LE set.
06-12-2021, 08:12 AM | #13 | |
I only installed the side skirts a month ago, that's why it's missing from the first three pics. Yes, I have MRC.
06-14-2021, 05:22 PM | #14 |
Not worried about a little rub at full lock. So 30s on the back and 35s on the front should keep a level ride. Did you try 35s front and rear before without any trouble?
