05-17-2021, 01:28 PM | #1 |
Drives: 2018 Camaro 1LS Join Date: May 2018
Non-RS Aftermarket Headlight Upgrade
Has anyone tried installing any aftermarket headlights to a non-RS 6th gen? Wondering how difficult it is to wire the LED bar underneath and if it can be tied into the factory vertical DRL's somehow?
05-17-2021, 03:00 PM | #2 |
While you didn’t put them in the original post the Morimoto units come with a harness to adapt to halogen equipped cars. I’m unsure if either of your options presented will.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
05-17-2021, 08:07 PM | #3 |
I have been considering the Morimoto as well as just OEM factory RS/SS headlights. Do you plan on selling your OEM headlights by any chance?
05-18-2021, 12:09 AM | #4 |
If you are going to put money into upgrading the headlights going to the OEM ones is a step in the right direction but you can still get better light output with a lot of the high quality LED offerings. If you going for looks then take you preference! I personally like the look of the Morimoto the best with their DRL being a switchback turn signal and the quad fixtures. Going OEM also requires an aftermarket relay harness such as the Gen 5 DIY one. I do have my lights but I plan to keep them for the foreseeable future.
05-18-2021, 11:05 AM | #5 |
Great information thank you FrostZ!
05-18-2021, 05:46 PM | #6 |
Sure thing! If you decide to go the Morimoto route there is a known issue with the DRL not matching the brightness of the bumper DRL's during the day. In a thread on those lights I helped another forum member with a fix I came up with myself.
05-19-2021, 08:53 PM | #7 |
I see, so they we're dim when they shouldn't have been but you've corrected that? And do they now dim at night with the DRL's?
05-20-2021, 06:10 PM | #8 |
Correct, with my harness they function exactly the same as OEM. I posted a how to in the DIY section of the forum if you decide to go this route.
Thread Tools | |
