06-28-2022, 07:03 PM | #1 |
Drives: SS 1LE Join Date: Jun 2022
Trunk lid for APR wing
I’m planning to add an APR wing for downforce during track events. I have a ‘22 SS 1LE so the trunk lid is not designed for the wing. So I’d like to buy a ZL1 1LE trunk lid from GM to use for the wing install.
Is GM Part # 84568190 the correct trunk lid for this? Thanks! |
06-29-2022, 10:10 AM | #2 |
i think you would be fine only the older cars 16-18 had any problems from what i remember are you going to add a front splitter also?
06-29-2022, 11:35 AM | #3 | |
Yes on splitter. It arrived this week. Plan to order wing and put then install at the same time... will do aero upgrades together with suspension and adding Girodisc brakes one thing leads to another... |
06-29-2022, 12:26 PM | #4 |
nice what splitter you going with it and what suspension mods? i have giro disc rings going on next month with a new set of hawk dtc60 pads
06-29-2022, 03:07 PM | #5 |
Thanks… I have the APR splitter that I found out about from a thread on this forum. Will only install it when I also have the wing so aero is balanced.
Otherwise planning camber plates and read end changes for camber too. I’m part of the Apex 18” wheel buy so will run those… maybe with R7s?? |
07-19-2022, 07:53 AM | #6 | |
07-19-2022, 05:46 PM | #7 |
Thanks for raising here. I was too slow on response… but if anyone else has a trunk lid then I’m very interested in buying it from you!
