06-04-2022, 05:25 PM | #1 |
Drives: lt1 Join Date: Feb 2022
car stuck in quality control
was told my car isnt being delivered because it was pulled for quality control. i read that how this happens is that every 5th car or so gets pulled aside after build and the whole process takes 2 weeks or more for testing, cleaning, diagnostics blah blah blah. has anyone ever heard of this
06-04-2022, 06:09 PM | #2 | |
Drives: Chevrolet Chevy Join Date: May 2022
06-04-2022, 06:24 PM | #3 |
Drives: 2022 2SS Join Date: Mar 2022
QC Audit
Yes, it happened to my GMC Sierra, not sure about every 5th one.
My truck had a paint mark on every fastener underneath the truck. Presumably to check the torque of each nut and bolt. You will see some paint marks on key fasteners on all GM cars, especially suspension components. My new 2SS has blue paint marks on the control arms.
2022 Camaro 2SS (6000 Vehicle Delivered to Customer 4/7/2022) Build Date 2/28/2022 GAZ Summit White B04 Black Metallic Rally Stripes IOT Navigation MX0 A10 Transmission CF5 Power Sunroof SLN Strut Tower Brace 56V 20" 5-spoke Carbon Flash Metallic Wheels NPP Dual-mode exhaust VTD 2nd Gen Ground Effects Carbon Flash Metallic 1996 Corvette LT4 Convertible Collectors Ed SOLD 2004 Corvette ZO6 LeMans Commemorative SOLD |
06-04-2022, 06:26 PM | #4 | |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Might be something new they implemented recently. (with in the last 2 years) If true, I'd guess they had issues with quality due to the constant stop and start back up production lines. But that's a guess. |
06-04-2022, 07:06 PM | #5 |
Drives: 2021 2SS 1LE Join Date: Aug 2020
Although it's a bummer from a time standpoint, I'd try to look at it as a positive. Namely, you will be getting a car where a lot of things have to checked to make sure it's been put together right.
06-04-2022, 10:10 PM | #6 |
Drives: 2016 Camaro SS and an old Lexus SUV Join Date: May 2015
Had a QC pull on my 2016 2ss as well...
My 2016 2SS was also pulled for QC. And, so far, it has been a perfect car. Long story short: it is like getting a free thorough inspection and repair if they find anything wrong. Not necessarily a bad thing.
06-04-2022, 11:52 PM | #7 |
Tri-County Camaro SWFL
This sucks but is a good thing. My 13 1LE got held. My uncle who retired from GM told me it was a good thing. He told me they basically disassemble the car and then reassemble it. My car has also been perfect. 9 years old. Almost 71k
06-05-2022, 12:48 AM | #8 |
06-05-2022, 04:48 AM | #9 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
That’s not true. I was at the factory when my 94 Z28 was built. Since I was there, they pulled my car for QC. There was no disassembly during the process. They test drove the car, ran it through a water test to check for leaks, checked over fasteners, shifter, panel fit and finish, etc. No parts were removed in the process. You do get a few extra stickers on the windshield.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
06-05-2022, 08:06 AM | #10 |
Yes I have heard of that process before and there’s really nothing to be concerned about. Think of a quality check as a good thing as that’s the way I see it. Good luck and at least you will get your car hopefully sooner than others waiting for theirs since you are in Michigan.��
06-05-2022, 08:58 AM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
I seriously doubt that when the comment was made about disassembling and reassembling the car was made that they meant it literally. It was probably just a figure of speech
There can be many levels /degrees of QC inspection. It could mean just a concentrated inspection of a certain area of interest, or it could be a complete precision measurement of various surfaces to compare them with factory specs, it could mean for example, rather than measuring a few panel gaps with a go/no go gauge to measuring all the panel gaps precisely, etc, etc. The bottom line is, that they are just going to take a closer look at the build of your car in some way or manor. That's a good thing. . |
06-05-2022, 09:06 AM | #12 |
Drives: 2017 1ss 1le HBM Join Date: Jun 2020
Just curious, how do you check the torque of a TTY bolt?
06-05-2022, 05:49 PM | #13 |
Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
Its a good thing, as mentioned it goes through additional static and dynamic tests. Happens to about 10-15 per day. When mine was being built, I had my buddy in GM flag my VIN so it purposely got held for QC evaluation. No problems since delivery other than a piece of dirt in the paint.
06-12-2022, 08:03 PM | #14 |
Drives: 2022 LT1 Rapid Blue Camaro Join Date: Jun 2022
Batch hold on new Camaro’s
I work at a Chevrolet dealership in Indiana and I called Lgr security that does security for the Camaro’s in Lansing Michigan and they told me last week that there was a batch hold on them but couldn’t tell me why. I have a new LT1 Camaro ordered and the Gm website shows it was built exactly one month ago but it’s just sitting in the lot at the assembly plant.
