Old 04-10-2018, 04:35 PM   #1
LeeCamaro1SS
LeeCamaro1SS's Avatar
Drives: 2018 White Summit Camaro 1SS w/NPP
Fuse Pull Question For NPP
Hey guys quick question about the fuse pull.
- When pulling the fuse does your check engine light will turn on?
- Does Valves stay open all the time on any mode?
- Is it louder or somewhat the same after pulling the fuse?
- And I know on Sport/Track mode, would you lose the popping/crackling noise if you pull the fuse?
Thanks
LeeCamaro1SS is offline   Reply With Quote
Old 04-10-2018, 04:40 PM   #2
Soleil
Soleil's Avatar
-No check engine
-yep the valves are permanent open
-it is always like track mode.
-nop I find the popping more specific the AT in manual mode 2nd gear.
Soleil
Old 04-10-2018, 04:43 PM   #3
LeeCamaro1SS
Originally Posted by Soleil View Post
-No check engine
Sweeeet Thanks
Old 04-10-2018, 08:14 PM   #4
Corvette_Mike
Corvette_Mike's Avatar
Drives: 2018 Camaro SS
What does NPP stand for?
Corvette_Mike is offline   Reply With Quote
Old 04-10-2018, 08:23 PM   #5
Lerch98
Lerch98's Avatar
Drives: 2017 2SS black on black on black.
I think that is the RPO code.
Lerch98 is offline   Reply With Quote
Old 04-11-2018, 06:18 AM   #6
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Mines been out for over 2 years. No codes
Old 04-11-2018, 01:39 PM   #7
Soleil
Soleil's Avatar
Originally Posted by LeeCamaro1SS View Post
Sweeeet Thanks
You’re welcome
Soleil
Old 04-11-2018, 01:42 PM   #8
Soleil
Soleil's Avatar
Yup it is the GM RPO Code for dual mode exhaust.
Soleil
Old 04-11-2018, 06:31 PM   #9
JZ_77
JZ_77's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Vert
No issues, sounds louder at higher speeds & constant rpm's than with it in imo.
JZ_77 is offline   Reply With Quote
Old 04-11-2018, 07:05 PM   #10
Ivan0072
2017 Red Hot Camaro 2SS
Ivan0072's Avatar
Drives: 2017 Camaro 2SS Red Hot
Why not just made all the settings to have the valves always open?
2017 Red Hot Camaro 2SS. Eibach lowering springs. MBRP Catback. Skipshift eliminator. K&N CAI.
Ivan0072 is offline   Reply With Quote
Old 04-11-2018, 07:14 PM   #11
Childs Play
Pizza & Wings Only $12.99
Childs Play's Avatar
Drives: 2017 Camaro SS
Some people do like to keep their exhaust quiet at certain times.
I personally like it when I leave my house at 5am to go to work. I’m pretty sure my neighbors appreciate it too.
That being said, I do keep meaning to do the fuse pull. Then I’ll just have to start the car with the garage closed.
I do wish they’d have an always open option built in. Would be nice but I doubt they’ll ever do that. :/
H-Town Camaro Club
Past Rides:
2012 Camaro 2SS/RS M6
2012 Camaro ZL1 A6
2017 Camaro 2SS M6
Childs Play is offline   Reply With Quote
Old 04-11-2018, 07:51 PM   #12
camaroras
Drives: 2018 Camaro 1SS 1LE
Is pulling the fuse any different than just manually setting it on track mode in the driver settings?
camaroras is offline   Reply With Quote
Old 04-11-2018, 08:35 PM   #13
BAMF
BAMF's Avatar
Drives: The Tumbler
I have read that a lot of people with the auto can tell a difference between the fuse being pulled and just leaving it in track mode particularly at highway speeds.
Does anyone know if there is a difference between leaving it in track mode and pulling the fuse for M6 owners?
2017 NGM 2SS, M6, Adrenaline Red interior, NPP, MRC, and a bunch of other nice stuff.
BAMF is offline   Reply With Quote
Old 04-11-2018, 10:05 PM   #14
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
I have the A8 and pulled the fuse after my NPP rattle returned (after the "glue" fix failed).
Have never heard the rattle since.
The main difference between setting the exhaust to Track mode all the time and pulling the fuse is that the exhaust valves are ALWAYS open with the fuse pulled. With Track mode exhaust, the valves still close down at lower RPMs.
I remember what it sounded like before I pulled the fuse. Now it is MUCH better!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
