01-18-2021, 08:03 AM | #1 |
LT1 and LT4 Engine Oil - Summarized
There's a lot of discussion here and on many other sites about ZL1 oils, but the topic looks simple.
Chevy's High Performance Owner's manual Supplement states: The LT1 and LT4 engines are factory filled with 0W-40 dexos2 oil. 0W-40 dexos2 engine oil is approved for both track and street use with the LT1 and LT4 (ZL1 only, not ZL1 1LE) engines. 15W-50 full synthetic engine oil may also be used for track use and is required on the ZL1 1LE, but after track use must be changed back to 0W-40 dexos2 for street use. ZL1 = 0W-40 both track and street 1LE = 15W-50 full synthetic track, 0W40 street Licensed 0W-40 dexos 2 brands: http://www.gmdexos.com/brands/dexos2/index.html Castrol Edge Mobil 1 ESP Mobil 1 ESP Formula Mobil 1 ESP x3 Kinda narrows the field.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 01-19-2021 at 07:41 AM. |
01-18-2021, 10:40 AM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Not saying the book is wrong, but the book is wrong.
Your table should say: SS 1LE/ZL1 - 0w-40 ZL1 1LE - 0w-40/15w-50 However, there is no difference between the LT4 in the ZL1 and ZLE. So I have never been very clear on the reason for the switch.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
01-18-2021, 10:56 AM | #3 |
Regardless, either 0w-40 and/or 15w-50 apply and only Mobil 1 and Castrol appear to make 0W40.
'20 ZL1 1LE A10,
01-18-2021, 11:33 AM | #4 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
The answer given from the Camaro team was the increased G loads capable in the ZLE require a thicker oil in the wetsump to avoid cavitation.
01-18-2021, 12:32 PM | #5 |
Ok. That’s good to know. Learn something on the board every day!
2017 HBM SS 1LE
01-18-2021, 02:03 PM | #6 |
It's odd that the subject Mobil 1 0W40 bottle does not have a dexos 2 indicator on it but the X3 does
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 02-09-2021 at 12:59 PM. |
01-18-2021, 02:13 PM | #7 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Just to make matters more confusing:
Most Castrol Edge you will find in stores is the A3/B4 variety, which is not Dexos 2 certified. I don't believe the Dexos 2 certified Castrol Edge is sold in North America, at least not in the 0W-40 viscosity. So you are pretty much stuck with Mobil 1 ESP if you wish to follow the Dexos 2 recommendation.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
01-18-2021, 02:15 PM | #8 | |
I spoke with my Chevy dealer today who said they use Mobil1 ESP.
Here they say Castrol EDGE 0W40 is dexos 2 approved (?) https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/29D862369255C1598025838300446319/$File/BPXE-B8NBC4.pdf Quote:
'20 ZL1 1LE A10,
01-18-2021, 11:51 PM | #9 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
See my thread on oils in Mechanical section. First sticky at the top.
BTW since Valvoline MST changed its recipe and lost Dexos2 certification i have been using Motul 8100 5W40 Dexos2. Plenty of other Dexos2 certified oils on GM list in that weight for much less than Mobil1 0W40 Dexos2. Arguably, 5W40 will give one better cold start protection, except for very cold winter temps. Anyhow, not gonna repeat what has been stated in the sticky. Please read it - it is all there and it is current. Cheers! |
01-19-2021, 07:45 AM | #10 | |
There are only 4 GM approved 0W40 dexos2 oils listed at http://www.gmdexos.com/brands/dexos2/index.html
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 02-09-2021 at 12:56 PM. |
01-19-2021, 11:20 AM | #11 | |
Also, not knowing how one uses the car, a manufacturer will specify the safest choice, such as 0w, in case folks decide to drive their Camaro in -20 temps...And i get that as well BUT: There is no reason to limit ourselves to this choice alone, as 5w40 Dexos2 is just fine for both street/track (as officially published in 2019 Track Preparation Manual) and so is even 5w30 Dexos1 (fully synthetic) albeit for DD only. The only exception is ZLE requirement to use 15w50 for track only due to G3Rs, BUT many, many, many folks track their 1LEs with G3Rs with w40 oil. Cheers! |
01-19-2021, 03:03 PM | #12 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
^ Agree. 5w/40 dexos should be absolutely fine. I think that would mean Amalie or Havoline Pro DS.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
01-19-2021, 03:32 PM | #13 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I just picked up some Royal Purple 5W-30 for my next change when the cam/heads go on, gotta have that zinc. On sale saved 12 bucks a jug.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-19-2021, 03:59 PM | #14 |
