06-17-2021, 06:56 PM | #1 |
Drives: Chevy camaro ss Join Date: Oct 2020
19 camaro ss lt4 fuel issues
Has anyone you know done an LT4 HPFP and LT4 Injectors in a 2019 or 2020 SS yet? I did the upgrade but problem being 1 code that we can't get figured out. Starts to make power then into limp mode it goes.
P00CA fuel pressure regulator solenoid supply voltage control circuit I've exhausted my resources looking for some help, if any can be provided. List of mods: D1x procharger Stage 2 intercooler kit Lt4 hpfp and lt4 injectors Race bypass valves Jms booster pump |
06-17-2021, 08:50 PM | #2 |
Have you logged your pulls when it goes into limp mode. Sound like your HPFP is not keeping up. Did you do anything on the low side like a DSX low side? If you have logged then you'll never figure it out. Is it fuel, timing (which seems unlikely)?
06-17-2021, 09:22 PM | #3 |
I have a jms booster pump to help with the low side... my tuner have data log, I doubt that it's fuel timing.
06-17-2021, 09:46 PM | #4 |
Drives: 2018 2SS 1LE Join Date: Feb 2021
sounds to me like the install of the JMS is not correct, maybe wires connected wrong or a loose connection. Since the code is coming from the FSCM. It goes into limp mode because of not enough fuel pressure when its calling for it.
The JMS has a lot of adjustments to it, make sure they are correct |
06-17-2021, 09:54 PM | #5 |
@bennett thanks for the input, I still relay it to my tuner.
06-18-2021, 10:10 AM | #6 |
sounds like the voltage is set too high in the JMS. It needs to be kept under 17.2 volts or it will cause issues like this. I wouldn't go higher then 17 volts.
2016 NFG 1SS A8
06-18-2021, 12:00 PM | #7 |
@kinglt1 the jms has been uninstalled and the problem is still there... but I think my issue more related with this guy https://www.camaro6.com/forums/showthread.php?t=575682
06-18-2021, 12:29 PM | #8 |
Code isn't from the FPCM the code is from the PCM and related to the high pressure fuel pump
06-20-2021, 09:26 AM | #9 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
Is the high side pump creating the pressure requested? Has the tune been setup for the LT4 pump and pressure?
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
06-20-2021, 10:02 AM | #10 |
Yes the car has been retuned for the hpfp & lt4 injectors.
06-20-2021, 12:43 PM | #11 |
Has high side and low side pressure been checked? If high side has pressure issues or something is off in tuning it will throw regulator code and will bypass fuel and not build pressure.
06-20-2021, 12:45 PM | #12 |
Thanks bro, I will forward this to my tuner.
